> Engine acting up after adding motor oil
post Oct 31, 2013 - 6:33 AM
DaijoubuDa
Joined Oct 15, '13
From USA
I checked the oil level a few days ago and it was really low. It was the first time I added oil since I bought the car last month, and I have no idea which type of oil the previous owner used. So, I just added about a quart of Castrol GTX 10W-30 High mileage motor oil to bring it up to the halfway point between low and high marks on the dipstick.
Since then, my engine (7afe) had been acting up. For instance, the engine sometimes vibrates very roughly when I stop at the traffic light or driving on highway; engine sometimes get really noise; and the car feels sluggish sometimes. (Symptoms are more noticeable after driving for awhile. Not with cold engine)
So, I am just wondering if this is normal or maybe something is wrong with the engine?
Note: Do you think it has anything to do with the catalyst converter? Last month, I was told that there was a small leak on the catalyst converter and I will need to get it replaced eventually.
This post has been edited by DaijoubuDa: Oct 31, 2013 - 6:34 AM
post Oct 31, 2013 - 1:20 PM
check the oil again. but adding oil shouldn't make a motor worse if you fill properly.
post Nov 1, 2013 - 3:55 AM
aiq
Joined Dec 24, '12
Is the check engine light on?
I would check the distributor cap and the plugs and the cables first.
This post has been edited by aiq: Nov 1, 2013 - 3:55 AM
post Nov 1, 2013 - 11:20 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
It's most likely a coincidence. The only way I could think that the engine would be that effected by oil is if there is heavy sludge and the oil is old.
post Nov 1, 2013 - 1:42 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
^+1, whenever you buy a used car. Always do a tune up because you never know when was the last time things were replaced.
post Nov 2, 2013 - 2:32 AM
DaijoubuDa
Joined Oct 15, '13
From USA
No engine light is on, and tbh the car just passed the NJ state inspection last week... Right now, I suspect there is also problem with the driver side strut/wheel because the car feels a little bouncy when I am driving. I guess I will just bring the car to a mechanic to look at just to be safe.
Current Oil Level:
http://i237.photobucket.com/albums/ff36/ry...1030_161833.jpg
This is how my cold engine sounds like at the moment:
http://s237.photobucket.com/user/ryopso/me...153825.mp4.html
post Nov 2, 2013 - 4:51 AM
mindkiller
Joined Apr 6, '12
From somewhere
your oil level is very low, its less than half, the oil level has to be at the second line.
post Nov 2, 2013 - 5:49 AM
mgnt232
Joined Mar 16, '09
btw on photobucket if you click get links, it will show serval codes. If you copy the IMG code, the picture will show in the threads instead of having to go to your photobucket
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Nov 2, 2013 - 6:21 AM
DaijoubuDa
Joined Oct 15, '13
From USA
QUOTE (mindkiller @ Nov 2, 2013 - 5:51 AM) *
I guess I was misinformed then. People always told me to add when it is below the "L" mark and it is fine if the oil is in between.
QUOTE (mgnt232 @ Nov 2, 2013 - 6:49 AM) *
I am aware of that but sometimes the picture seems to stretch the page too big/too long >.>
post Nov 13, 2013 - 6:46 AM
ILoveMySilly97
Joined Mar 8, '12
Yes its suppose the oil level is suppose to be in between the L-F but it's just common sense that it's best to either be halfway or full. Just like how we wouldn't want to go out of town on a gas tank that's close the E/L.
Lo-Fi Version Time is now: February 18th, 2025 - 6:19 AM
