> Engine Problem, Stalling and Rec drop off prob
post Jan 28, 2004 - 7:11 PM
Shortty
Joined Jan 28, '04
From Mids
Hey guys,
this is my first post, and i'm hoping you can give me abit of help.
I have recently bought a 94 6gc. It is a UK GT spec, with the 3sge engine. But it has a problem, well actually it has a few problems but i'll ask about those in due course.
Usually when the engine is cold, it will sometimes drop down in revs, sometimes to the point of stalling, but mostly catching itself at about 200 - 400 rpm, then picking back up. It doesn't seem to matter whether lights or air con is on or off, and it does it worse when i press hard on teh accelerator and then let off completely.
It also doesn't idle very smoothly, altho the rpm gauge says its at around 800 rpm on warm idle, it still feels like it's a bit rough and vibrates a bit. Sometimes i find the idle hovers around aswell sometimes dropping then over revving a bit.
I've checked the air filter, and it's alittle bit dirty but not bad enough to cause this i'd have thought. I would like your help on what to look at as i dont want to pay the garage a fortune to not find anything - no engine light has come on as yet..
Someone i know said it may be worn spark leads, but rather than just replace them i thought i'd see if anyof you have the same prob.
Thanks in advance
Shortty
post Jan 28, 2004 - 8:37 PM
BlackSTX
Joined May 17, '03
From Florence, KY
Have you had a tune-up or anything since you've bought the car? That might be a good place to start.
post Jan 28, 2004 - 8:53 PM
ghostdog
From ny to philly
how many miles do you have on your car?
check plugs/wires, distributor cap/rotor, and fuel filter (my guess)
post Jan 28, 2004 - 9:08 PM
Shortty
Joined Jan 28, '04
From Mids
Car's got 92'000m on it. it has a full service history, and it was toyota dealership servicing up till a year ago, and then was a private one.
Last service was at 90'000.
As for checking stuff, i thought i'd get a bit of input first. This may sound really really dumb, but it's hard to find the spark plugs, i just can't see them, i've only looked at night with poor lighting, but the 3sge hides them away somewhere. No really!
Same really for fuel pump, it would be quite a major job, so would like to check the easier to do stuff first..
Cheers for your help
Shortty
post Jan 29, 2004 - 11:54 AM
Junior
Joined May 5, '03
From Toronto
I would give it a full tune up and see what that does. Oil, oil filter, air filter, plugs, wires, cap and rotor, fuel filter. This all **** that should be done any time you buy a used car.
post Jan 29, 2004 - 12:46 PM
Shortty
Joined Jan 28, '04
From Mids
cool, cheers for that, i'll get on to it. Gonna take a while as i want to do it all myself, plus it's about -5 centigrade here at the moment! Got a feeling thinking back that it may be the fuel filter, as the guy who had it before me said he always kept tank at least half full, then when he sold it he let it drop to nearly empty, so that may have pulled through all the crap at the bottom of the tank
Shortty
Lo-Fi Version Time is now: November 27th, 2024 - 11:41 PM
