> 1998 Celica 2.2 question., Engine Swap
post Oct 31, 2013 - 8:55 PM
Lemonoh
Joined Oct 31, '13
From Am180303
Hi everybody. I'm new to celica's and toyotas in general after coming from mainly building 13b rotarys. I found a nice 1998 Gt with an excellent body( which is very rare here) but the water pump failed and it over heated so it was sold cheap. The only motor here for sale are 2001 Camry motors. I know both engines are roughly the same except the Camry has coils. My question is can I swap the 2001 Camry motor in? I need to keep it the same motor for autoX classing. Can I swap the distributer over along with my other accessories and make it work or does the celica head need to be swapped over to the Camry block? Any info would be great. Thanks
post Oct 31, 2013 - 11:29 PM
Syaoran
Joined Jan 4, '12
From US
You would use the Camry engine with all your celica electronics. New engine might not have EGR and most likely won't have a fuel return, and the header will not fit, nor the oil pan will be the same.
Those are a few basics, but yes, you can use the camry engine with some details changed here and there.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 1, 2013 - 12:09 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
fuel return has nothing to do with anything. the OP will use his rail and manifolds.
im not 100% sure if you can knock out a block off so you can use a distributor. not even sure if the new cams are keyed to turn a distributor. the 6th gen is a terrible autocross car, its heavy and slow with the 2.2L in it.
not sure where you are but there are several engine swaps you could look into. 3S-GTE (which is a stock engine for the 6th gens.) BEAMS 3S-GE (also a stock engine for 6th gens) and there are V6 options
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 1, 2013 - 6:37 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Smaay @ Nov 1, 2013 - 1:09 AM) *
hmmmmm I just cant agree with you on that
OP, this is off topic but Im just curious, will you but using the car is stock class?
エキサイティングカーレーシングチーム!
post Nov 1, 2013 - 8:00 AM
Lemonoh
Joined Oct 31, '13
From Am180303
The car was going to be in street prepared class. Stock engine and drivetrain with suspension and brake upgrades. That's the class my friends run and its mostly low end cars for a laugh rather then to be competive. After reading your replies I am interest in this 3S-GE motor even if it outclasses me from my friends.
http://torontojdm.com/cart.php?target=prod...category_id=117
Not sure if I linked that right but is that the red top motor you mentioned. It's a complete motor with harness and ecu. Anything else you can think of that I'd need before starting. I may just replace the water pump on the stock motor for now and gather the parts and materials for a swap after I've learned an bit more about the car
post Nov 1, 2013 - 9:11 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Actually a 3SGE swap is still allowed under the Street Prepared Class so it could be a worth while swap.
You could even go with a 3SGTE and still be able to compete in FSP
エキサイティングカーレーシングチーム!
post Nov 1, 2013 - 9:28 AM
qatar11
From Lake Orion, MI
QUOTE (Tigawoods @ Nov 1, 2013 - 7:37 AM) *
2nd... Its actually a very well balanced car that brakes and turns with the best of them...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Nov 1, 2013 - 9:33 AM
qatar11
From Lake Orion, MI
QUOTE (Tigawoods @ Nov 1, 2013 - 10:11 AM) *
Would you want a turbo car (without antilag) in autoX? I would imagine the all motor 3SGE would be "idea" here...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Nov 1, 2013 - 9:47 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I think it would be fun to experiment with. And it really really depends on the course. It would do just fine on a fast course, but it would be HORIFFIC on a tight course. I raced an event last month where the course was so tight even my car did terribly ( I can imagine it would have been much worse with a 3S)
I can see a 3SGE being a bit more versatile throughout the different courses you get
good point bringing that up
This post has been edited by Tigawoods: Nov 1, 2013 - 9:47 AM
エキサイティングカーレーシングチーム!
post Nov 1, 2013 - 2:56 PM
mi645
Joined May 23, '12
From northridge,CA
LOL THE 6 GEN CELICA IS PERFECT FOR AUTOCROSS ITS ACTUALLY OTHER EVENTS LIKE TRACK UD HAVE A HARD TIME WITH THE 2.2 BUT WITH TEH GEAR RATIO SET UP AND 2.2 IT WORKS GREAT FOR AUTOX.
Lo-Fi Version Time is now: January 10th, 2025 - 6:53 PM
