> 2AZ lightweight block option., Article suggests 5S/2AZ interchangeability.
post Nov 4, 2013 - 1:28 AM
H8TRAIN
Joined Oct 20, '13
From Cal Bay Area
Be careful you don't get scammed into an iron block while in Africa.
This article suggests that the 5sfe and 2azfe blocks are so similar, that they can be interchanged.
Chances are that half your engine is actually made of cast iron engine block (5S-FE) extracted from older models(less than 2001). It recently came to my notice that these engines are rebuilt locally and sold to unsuspecting customers as full aluminium engines.
For those that are concerned about their cars balance or overall weight, this could be useful. I would be interested in building an all-alloy 5sfe. And If that is possible then a lightweight 3sge (stroker) may be possible as well.
post Nov 4, 2013 - 7:08 AM
Africa!
This post has been edited by SwissFerdi: Nov 4, 2013 - 7:08 AM
post Nov 4, 2013 - 12:30 PM
RavenAegis45
Joined Jun 25, '08
From CA
QUOTE (H8TRAIN @ Nov 4, 2013 - 2:28 AM) *
Hmm thats very interesting, I don't see how they could manage that though since all S-series engines have timing belts and AZ-Series have timing chains not to mention all the other components used for VVT-i, i'm pretty sure the only S-series engines that have the oil passages on the blocks for VVT-i are the red and black top beams, so i'm genuinely curious to see how they get these engines to work lol
post Nov 4, 2013 - 11:08 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
ooo an alloy block 3sge redtop motor yay but in your dreams!
This post has been edited by BonzaiCelica: Nov 4, 2013 - 11:46 PM
post Nov 4, 2013 - 11:40 PM
A wim bawe A wim bawe, the lion sleeps tonight
post Nov 4, 2013 - 11:52 PM
H8TRAIN
Joined Oct 20, '13
From Cal Bay Area
QUOTE (RavenAegis45 @ Nov 4, 2013 - 12:30 PM) *
The article is vague about the technical parts. I don't know much about the 2az, but I agree that it doesn't appear to have any mating potential with the s series. But if people are in fact getting there cars back with a 5s/2az swap done, there is likely something useful to learn.
post Nov 8, 2013 - 8:27 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
I think they're saying half because the S has an aluminum head like the AZ does, not because someone swapped the bottom end. The AZ could swap, it's roughly the same size and there are a couple years of overlap where the MZ and AZ series were in the Camry, however I'm not sure about height under hood.
post Nov 8, 2013 - 9:48 AM
bnr32celica
Joined Jan 16, '12
From 860, ct
It'd be interesting to see for sure. Far as I understood, the AZ series has a different bellhousing bolt pattern, but that can be rectified easily.We'll find out, I have a random blown tC trans in my garage that will get junked other than the bell. I want to see if it bolts to the E153 and such.
post Nov 10, 2013 - 4:52 AM
H8TRAIN
Joined Oct 20, '13
From Cal Bay Area
QUOTE (bnr32celica @ Nov 8, 2013 - 9:48 AM) *
bnr32celica, I'm interested in the results of that. 2az would be my favored swap, but im lacking information like this.
post Nov 10, 2013 - 10:19 AM
Neon90424
Joined Jan 19, '11
I think thats the 2.0 forged crank engine i wanted to try and see if its crank could be used in a 3s as a lightweight option
Lo-Fi Version Time is now: November 29th, 2024 - 9:52 PM
