> vibrations inside the whole car, help help help !!!
post Nov 13, 2013 - 9:26 AM
joaquin
Joined Apr 21, '13
From california
Ok so today i turned on my car and its started to sound really loud inside. It gets really bad once i hit 1000 rpms. Basicly the whole car shakes inside. Can someone guide me to what this problem could be. I changed the motor mounts no to long ago.
Thanks a lot
post Nov 13, 2013 - 11:15 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
What motor mounts did you install? If you used the poly inserts, I've heard of these causing a ton of vibration from the start for the first bit untill they get "broken in".
Even if you've just replaced with factory mounts, your old ones could have been squishy enough to not cause this.
Give it a bit of time and they will probably soften up a bit, and should reduce teh vibration.
My Celica!
post Nov 13, 2013 - 11:18 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
if it was a engine mount issue, it would be immediate. not something t hat just suddenly happens, unless a bolt fell out.
I would need more information on what is going on to give a proper diagnosis
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 13, 2013 - 11:32 AM
joaquin
Joined Apr 21, '13
From california
Yeah i got the stock motor mounts but i got them like 8 months ago i think they got broken in.
Well i was driving to the store turned the car off but before i did that i took a quick turn. Then i got back in and thats when it started to vibrate. I also notice that when i hit 1000 rpms it vibrates and shakes alot inside the car even when im in neutral.
post Nov 13, 2013 - 1:21 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (joaquin @ Nov 13, 2013 - 12:32 PM) *
Ohh I thought this occured just after install.
My Celica!
post Nov 13, 2013 - 2:59 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Maybe you had an engine mount that went bad prematurely?
post Nov 14, 2013 - 7:28 PM
blackliftback
Joined Mar 1, '12
From iowa
I would check for spark in all cylinders.
post Nov 26, 2013 - 7:52 PM
trdproven
Joined Aug 2, '05
From Guam
check all motor mounts even see if it is secured or cracked, check your idle or performance, that can cause shaking, like ^ said, can be a bad spark plug, like you only have 3 cyl running.
This post has been edited by trdproven: Nov 26, 2013 - 7:53 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 15th, 2025 - 4:58 PM
