> Ignition switch
post Nov 14, 2013 - 12:59 PM
valerit1
Joined May 2, '06
From Nevada
Regarding the ignition switch - is it possible to remove it without pulling the steering wheel and shaft assembly?
Can it be opened to see the contacts - it is an intermittent problem, so testing by the Toyota manual will not be conclusive? Thanks!
post Nov 14, 2013 - 1:46 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes remove the plastics around the wheel and under the gauges and you can see the ignition stalk
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 14, 2013 - 4:54 PM
valerit1
Joined May 2, '06
From Nevada
Which brand should I get? Does OEM make a difference in this case?
post Nov 14, 2013 - 6:20 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
what are you looking to replace? the ignition? I suggest sticking with OEM.
Lo-Fi Version Time is now: November 29th, 2024 - 5:26 PM
