Injectors removal 5SFE, any tutorial about injectors removal?? |
Nov 20, 2013 - 1:25 AM |
Enthusiast Joined Jul 15, '07 From Mexico Currently Offline Reputation: 2 (100%) |
I have my brother´s celica with the technician , he told to us that two injectors are clogged, but he dont have any idea about how to remove them since he is computer/scanner specialist so i would like to know if somebody have the 5SFE injectors removal tutorial.
Thank you!! |
Nov 20, 2013 - 5:29 PM |
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude.
1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Nov 21, 2013 - 1:37 AM |
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude. 1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. Thank you! i have followed your instructions and it was quiet easy. |
Nov 21, 2013 - 6:39 AM |
It's easy, but might be a little hard for someone who doesn't have mechanical aptitude. 1. Remove the valve cover, which requires taking off four 30mm nuts (spark plug tube nuts). 2. You'll see the fuel rail behind the cams. There's two 12mm bolts holding it onto the head. Remove them. You should now be able to pull off the rail with all four injectors. However, you MUST depressurize the fuel system before attempting this, as you WILL spray gasoline all over your engine, hands, arms and face if you don't. Thank you! i have followed your instructions and it was quiet easy. ¡Cómo no! You're welcome. -------------------- 1993 Celica GT Coupe - sold
Nov 26, 2013 - 7:45 PM |
one of the crappy reasons with the 5s
Lo-Fi Version | Time is now: January 9th, 2025 - 1:46 PM |
