7 Pages V  < 1 2 3 4 5 > »
> 1994 Celica's Reconstruction, Beams Swaped as of 3/5/16
post Jul 29, 2015 - 2:09 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
QUOTE (msk59 @ Jul 29, 2015 - 11:26 AM) *
I read through your post and that is significant amount of work done to the car. Excellent Job.
Thanks! I still have a long way to go though.
JDM Part King
post Jul 29, 2015 - 3:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
And a short time to get there, I'm west bound just watch 'ol Bandit run!
2001 Miata LS 5-speed
post Sep 10, 2015 - 10:04 PM
1994Celica
Joined Aug 5, '09
Progress today! Although nothing huge. New struts and tein springs are on. This weekend hopefully k can get the subframe back on and new sway bar mounted
JDM Part King
post Sep 11, 2015 - 5:02 AM
Box
Joined Feb 23, '12
From Warrior, AL
post Sep 11, 2015 - 7:50 AM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Sep 11, 2015 - 6:02 AM) *
One thing at a time. Rear suspension needs to be done first. After that then I can get into the horrible engine swap.
JDM Part King
post Sep 26, 2015 - 2:30 PM
1994Celica
Joined Aug 5, '09
Progress today! Entire subframe is back on with poly bushings. New st swaybar is on as well. Tomorrow I'll put on all my new braking stuff and the rear end is more or less done!
JDM Part King
post Oct 3, 2015 - 7:02 PM
1994Celica
Joined Aug 5, '09
Car is on 4 wheels again! It has new calipers, rotors and stop tech stainless steel brake lines. Also poly bushings and an ST sway bar. It took longer than it should off but it's finally done. Here's some pics of it completed.
JDM Part King
post Oct 3, 2015 - 8:53 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 3, 2015 - 8:58 PM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Oct 3, 2015 - 8:53 PM) *
It was raining today and my brothers Buick is in front of it and currently not where it can move.
JDM Part King
post Oct 5, 2015 - 8:20 PM
ooohh, i love shiny bits. pretty.
post Oct 5, 2015 - 11:05 PM
1994Celica
Joined Aug 5, '09
QUOTE (njccmd2002 @ Oct 5, 2015 - 8:20 PM) *
I do as well! I need to do the front too, but that wont get done till I start my Beams swap.
JDM Part King
post Oct 6, 2015 - 4:19 AM
i remember when i started my beams swap, it was like "nothing", lol.. forgot to connect the grounds to the intake manifold. what a headache that was..
post Oct 6, 2015 - 5:15 AM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 6, 2015 - 6:44 PM
i meant nothing, cuz the bastard did not start!!! took me 2 days to figure it out...
post Oct 6, 2015 - 9:47 PM
1994Celica
Joined Aug 5, '09
I'm honestly not worried about getting the engine running. I'm more concerned about swapping to a manual
JDM Part King
post Oct 7, 2015 - 11:58 AM
Manual swapping is a breeze if you got all them parts. Plug and playa!
post Oct 7, 2015 - 12:56 PM
mkernz22
Joined May 10, '10
From MA
Literally the easiest job ever if you have all the parts. I'd rather do a manual swap again than do the rear bushings.
post Oct 7, 2015 - 3:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hardest part would be putting in the master cylinder and pedal assembly, the rest is just changing a clutch more or less.
post Oct 8, 2015 - 8:22 PM
1994Celica
Joined Aug 5, '09
Well thats good to hear. The rear bushings weren't really that bad but then again I did have a shop press the new ones in. I think I have everything except the rubber clutch lines. I won't be changing out the clutch on the beams and I'm just going to drop the engine and trans as one unit. Engine only has 55k miles so clutch should be okay.
JDM Part King
post Oct 9, 2015 - 11:07 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
So your not going to even take off transmission to check it?
I believe Mr 2gr swapper guy didn't check either
This post has been edited by BonzaiCelica: Oct 9, 2015 - 11:09 AM
Lo-Fi Version Time is now: November 25th, 2024 - 1:23 PM
