7 Pages V  « < 2 3 4 5 6 > »
> 1994 Celica's Reconstruction, Beams Swaped as of 3/5/16
post Oct 9, 2015 - 3:28 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
Nope. If it comes back to bite me in the ass then so be it.
JDM Part King
post Oct 9, 2015 - 4:43 PM
Yup. I changed it a year or 2 later
post Oct 9, 2015 - 9:50 PM
QUOTE (1994Celica @ Oct 8, 2015 - 9:22 PM) *
I won't be changing out the clutch on the beams and I'm just going to drop the engine and trans as one unit. Engine only has 55k miles so clutch should be okay.
That is a bad decision.
Don't go through swapping to find out the clutch is toast.
Just change it when it's 100% easier not in the car.
post Oct 10, 2015 - 4:28 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Yup buy 99 Celica pressure plate and a stage 2 5sfe disc or just a stage 2 exedy clutch kit
post Oct 10, 2015 - 5:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd just go ahead and do the clutch while everything is easy to get to as well, especially since once it's all quick and stuff you'll never stop driving it. redface.gif
2001 Miata LS 5-speed
post Oct 10, 2015 - 9:07 PM
1994Celica
Joined Aug 5, '09
I know it's probably a good idea to swap the clutch but money is super tight for me.
JDM Part King
post Jan 30, 2016 - 10:03 PM
1994Celica
Joined Aug 5, '09
So a lot happened today. No more 5s and auto. Next thing to do is clean the engine bay replace various the various hoses and what not while I have access to them. Then replace my control arm bushings and sway bar. Then after that the beams will go in. It's been a long day getting it out but my brother with my help were able to get it out using smaays guide.
This post has been edited by 1994Celica: Jan 30, 2016 - 10:04 PM
JDM Part King
post Feb 3, 2016 - 6:46 PM
Box
Joined Feb 23, '12
From Warrior, AL
Wooo, now can sell the drivetrain to your average Toyota consumer=profit. tongue.gif
This post has been edited by Box: Feb 3, 2016 - 6:46 PM
post Feb 7, 2016 - 7:53 PM
1994Celica
Joined Aug 5, '09
Soon.....
Yesterday I cleaned my engine bay up some. Need to do another go around and then it should be good. I had to work but my brother kept on and he got my control arms with poly bushings in and my upgraded sway bar and end links. This Saturday will be installing the clutch pedal and other manual things
JDM Part King
post Feb 9, 2016 - 9:23 AM
Dat fender. gosh....
post Feb 9, 2016 - 3:09 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Feb 9, 2016 - 10:33 PM
1994Celica
Joined Aug 5, '09
QUOTE (njccmd2002 @ Feb 9, 2016 - 9:23 AM) *
Yeah plastidip shows dirt and grease badly...
This post has been edited by 1994Celica: Feb 9, 2016 - 10:34 PM
JDM Part King
post Feb 13, 2016 - 10:27 PM
1994Celica
Joined Aug 5, '09
My car now has three pedals and a shifter! Wiring is next which is worrying me but I think I'll get through it. After that the beams will go in.
JDM Part King
post Feb 14, 2016 - 3:05 AM
Box
Joined Feb 23, '12
From Warrior, AL
Huzzah, appropriate amount of pedals!
post Feb 14, 2016 - 11:09 AM
enderswift
Joined Jul 12, '08
wiring is not a big deal. you literally have to run one one short wire between two fuse boxes near the pedals. I might be able to find my marked up wiring diagram
This post has been edited by enderswift: Feb 14, 2016 - 11:10 AM
post Feb 15, 2016 - 2:23 AM
1994Celica
Joined Aug 5, '09
QUOTE (enderswift @ Feb 14, 2016 - 12:09 PM) *
If you could that would be most helpful!
JDM Part King
post Feb 20, 2016 - 9:04 PM
1994Celica
Joined Aug 5, '09
Got some minor stuff done today. New Beams cluster is in, manual rear engine mount is in, clutch lines run. Most of the wiring is sorted out as well so hopefully next Saturday the engine can go in.
JDM Part King
post Feb 20, 2016 - 10:26 PM
Box
Joined Feb 23, '12
From Warrior, AL
Woo!!!!!!
post Feb 27, 2016 - 7:39 PM
1994Celica
Joined Aug 5, '09
Beams engine is in. Still need to figure out how to get the car to start since it was an auto and now a manual. Need to make a customer bracket for the fuel filter. Need to also figure out why my clutch won't bleed and get the return spring for it.
JDM Part King
post Mar 1, 2016 - 1:03 AM
mkernz22
Joined May 10, '10
From MA
You better hope the clutch and rear main seal are good..
Did you replace the slave cylinder on the trasnmission?
Lo-Fi Version Time is now: November 25th, 2024 - 3:37 PM
