> Can you reuse Flywheel Bolts?
post Nov 21, 2013 - 8:35 AM
qatar11
From Lake Orion, MI
What's everyone's opinion on re-using flywheel bolts? I haven't poked into the service manual yet... just getting opinions.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Nov 21, 2013 - 8:45 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Look up the torque spec, if it's X ft/lb plus X degrees (like 30ftlb and then 90 degrees) they are torque to yield and are to be used once then discarded since they've been stretched to their limit when they were installed. If the torque is just a ft/lb measure then they may be OK to reuse. There may also be a spec for length you can measure to determine their condition. When in doubt, replace.
post Nov 21, 2013 - 8:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the service manual and popular opinion says not to re-use them. HOWEVER I have re-used them on a stock application car and had no issues.
The bolt is a torque to yield meaning the bolt is stretched and therefore losses strength if used twice. but like i said, i have done it several times with no problems. There isnt an ARP bolt for the 5S-FE but the 7A-FE can use the 4A-GE ARP bolts and those can be re-used.
torque for OEM bolts is 36 lbs and then turn the bolt another 90 degrees. ARP bolts is 58 LBS using moly lube or 80 LBS using 30W oil
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 21, 2013 - 10:18 AM
czwalga
Joined Sep 27, '10
From pittsburgh
I'll reuse anything that isn't torque to yield.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Nov 21, 2013 - 2:32 PM
richee3
Joined Jun 29, '08
From Denver
As cheap as the OEM ones can be, I choose not to reuse them, but I've read many sources saying you'll be fine as long as you couple them with a little Loctite.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 21, 2013 - 10:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^^ yes i forgot that part, use locktite blue
post Nov 22, 2013 - 7:29 AM
Hmm. I've only had to install flywheel bolts once but I used new, and blue loctite. It was an easy decision for me since tearing it apart once was hard enough, I didn't want to do it again for lack of proper hardware.
post Nov 22, 2013 - 8:19 AM
mkernz22
Joined May 10, '10
From MA
I've reused mine twice already. When I did my manual swap and then once the crappy clutch went out. Been running the bolts for almost 2.5 years with no problems. Just had loctite on them both times.
post Nov 22, 2013 - 8:47 AM
qatar11
From Lake Orion, MI
QUOTE (mkernz22 @ Nov 22, 2013 - 8:19 AM) *
Reusing sounds okay so far... the loctite.... I may be a little skittish on...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Nov 22, 2013 - 11:03 AM
I've reused mine at least 4 times so far. There are no issues and no need to spend money.
post Nov 22, 2013 - 11:18 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
yup me too blue loctite. and you'll be fine i replaced my flywheel over 20,000 miles and im fine. even lago said he's good and he outputs a lot more torque with turbo engine
post Nov 23, 2013 - 12:04 PM
reuse, apply blue loctite, somthing like 76ftlbs, IIRC.
they arnt torque to yeild, so they are reusable, IMO.
post Nov 25, 2013 - 11:22 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i just checked my paperwork, the 7A-FE is not TTY, its 58 lbs with blue locktite. I havent found the 5S information yet.
post Nov 25, 2013 - 9:42 PM
Bitter
Joined Mar 11, '06
FLYWHEEL INSTALLATION
Apply adhesive to 2 or 3 threads of the bolt end. Adhesive: Part No. 08833 - 00070, THREE BOND 1324 or equivalent.
Install the flywheel on the crankshaft.
Install and uniformly tighten the 8 bolts in several passes, in the sequence shown (see image). Torque: 88 Nm (65 ft. lbs.)
post Nov 28, 2013 - 5:23 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
well there you go. i find it funny how toyota has different specs between cars. the 7th gen are both 36 lbs and 90 degrees. So is my Supra
Lo-Fi Version Time is now: January 15th, 2025 - 7:35 AM
