> 3sgte celica problems
post Nov 25, 2013 - 2:52 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
Hello, i'm just going to start off as im a complete noob but i will try my best to describe the problem i'm having, yesterday i bought a 96 gt celica convertible (for cheep) and i found out it has a running 3sgte in it. the problem i'm having is that it idles extremely rough. and will die unless i rev it up abit but while driving and my foot on the throttle it runs fine, when i'm coasting (foot off the throttle for awhile untill rpms go down) the car will die if i don't keep it my foot on the throttle, a side note it is a very cold day today so i'm not sure if its the dense air or it's something completely different. but it almost seems like it's not getting gas if i'm not mistaken. but again i'm a noob, any help would be greatly appreciated
post Nov 25, 2013 - 3:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
Could be the IACV is completely clogged or seized, I'd look there first.
3S-GTE convertible? I think that might the first I've heard of anyone doing such, well at least in some time anyhow.
This post has been edited by Box: Nov 25, 2013 - 3:05 PM
2001 Miata LS 5-speed
post Nov 25, 2013 - 3:24 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
Wow, thanks for the fast reply, should i clean it or replace it? and i can take pictures, i got this car for 250$. i'm just trying to make it a reliable car again.
post Nov 25, 2013 - 3:40 PM
Box
Joined Feb 23, '12
From Warrior, AL
$250 or $2,500!? Either way that's a hell of a deal with the 3S-GTE... Going to be a lot of jealous people here now. tongue.gif Definitely try and clean it first, more often than not it just needs cleaning.
Should make a project thread when you have the time.
This post has been edited by Box: Nov 25, 2013 - 3:41 PM
post Nov 25, 2013 - 3:42 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
250, a mother sold me her sons car because he had moved and left it sitting in her yard for 3 years, and she handed me a perfect title and everything, it runs fine, just idles rough, also i just took a quick look at and i'm having a hard time finding the iacv also it needs wiring done, it looks really spotty, but it has been sitting for abit and for 250 i can't really complain.
post Nov 25, 2013 - 3:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
You're extremely lucky, that is probably the deal of the year. Which you need to figure out which generation 3S-GTE it is, but either way it's worth way more than what you paid. The IACV is near the underside of the throttle body. Get the idle and wiring straightened up and you'll have a Hell of a car.
post Nov 25, 2013 - 5:21 PM
cardshark525
Joined Jan 12, '09
From State College, PA
QUOTE (zomblaya @ Nov 25, 2013 - 3:42 PM) *
post Nov 25, 2013 - 6:53 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
if you need an iac i can help you. pm me!
post Nov 25, 2013 - 7:05 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
QUOTE (Box @ Nov 25, 2013 - 3:45 PM) *
How can i tell what gen it is? Also, i cannot seem to find the iacv, i looked at some pictures online but where mine is is something completely different? but i will check where you mentioned on the throttle body, the picture i looked at was on the firewall Ps. did garret make a turbo to fit the 3sgte? thats the only indication i can find on the turbo.
post Nov 25, 2013 - 7:14 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
can you post a pic? gen i & ii used a toyota ct26 turbo. gen iii used a toyota ct20. gen iii i believe has an 8 hole exhaust manifold. gen ii had either 7 or 9 holes for the exhaust manifold. get some pics up!
post Nov 25, 2013 - 7:24 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
QUOTE (garin @ Nov 25, 2013 - 7:14 PM) *
yeah i will tomarrow when it's bright out. but i am warning you the engine bay and the wiring is such an eyesore!
post Nov 26, 2013 - 1:26 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
post Nov 26, 2013 - 1:49 PM
Box
Joined Feb 23, '12
From Warrior, AL
Looks to be a second gen from a MR2.
post Nov 26, 2013 - 1:52 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
Ah okay, i'm new to celica's so i wouldn't know if that is good or bad. And i still can't seem to find the iacv? Also, the car has 108xxx miles on the odo. (again don't know if thats good or bad.)
post Nov 26, 2013 - 2:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
It's better than what it came from the factory with. tongue.gif The second gen makes 200 hp, though it's easy enough to increase that. It's possible that they removed the IACV, for whatever reason, and have a block off plate on it.
post Nov 26, 2013 - 2:16 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
Alright.. So next step would be to find a leak? And eventually i want to increase the hp on it, but not untill i give her what she needs.
post Nov 26, 2013 - 2:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
A leak would cause idle to be high and not drop, you have the complete opposite problem. It's something to do with the IACV whether it's clogged, broken, or not even there.
post Nov 26, 2013 - 2:34 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
Does this help?
post Nov 26, 2013 - 2:44 PM
Box
Joined Feb 23, '12
From Warrior, AL
The IACV is what's at the bottom with the three tubes.
This post has been edited by Box: Nov 26, 2013 - 2:45 PM
post Nov 26, 2013 - 2:56 PM
zomblaya
Joined Nov 25, '13
From tulsa ok
i tried taking a picture of under my TB
Lo-Fi Version Time is now: November 27th, 2024 - 6:40 PM
