4 Pages V  < 1 2 3 4 >
> Upgrading to an 8 speaker system, with shallow woofer on door, Woofer is in, 12/21/13
post Dec 3, 2013 - 2:51 PM
The_enD
Joined Apr 12, '13
From Bulgaria
That's what why I said small...sealed.
Nice response in the overall low range with it taking as little space as possible.
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Dec 3, 2013 - 10:15 PM
well i bought the shallow woofers, and well see, if they dont sound good, i can make them fit in the rear..
post Dec 3, 2013 - 10:25 PM
Box
Joined Feb 23, '12
From Warrior, AL
If that happens then what will you do for the bottom door? redface.gif Hopefully this works out. I'm wanting to do a very similar setup myself, just need to find the premium door panels and brackets first.
This post has been edited by Box: Dec 3, 2013 - 10:26 PM
2001 Miata LS 5-speed
post Dec 3, 2013 - 10:32 PM
the 8 speaker panels you can make them yourself. i bought the lower grill, and got the upper speaker grills, i cut my door cards... and presto...
post Dec 3, 2013 - 10:40 PM
Box
Joined Feb 23, '12
From Warrior, AL
I suppose I could do that... Just can use whatever grilles are provided with the component set. I just trust the factory's ability of getting things perfectly symmetrical more so than myself. tongue.gif
post Dec 4, 2013 - 12:39 AM
QUOTE (Box @ Dec 3, 2013 - 9:40 PM) *
its really easy, http://www.6gc.net/forums/index.php?showto...l=speaker+grill
QUOTE (Special_Edy @ Dec 3, 2013 - 11:17 AM) *
In my celica I run the 4', the 6.5' and the tweeter off of the head unit. Then I have a small 300 watt amp under the driverseat to power the 8" speakers and a 600 watt amp in the trunk to power the 12s
njccmd - it looks like you are missing the extra insulation for the door. There is a metal plate that bolts over the hole in the door and a plastic block that reinforces the door panel. I found mine in a '98 vert in the scrap yard with an 8 speaker setup
found it!!! your pic..
post Dec 4, 2013 - 12:59 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Dec 3, 2013 - 11:39 PM) *
I was more concerned with cutting out for the mid-range speakers and tweeters, but that's good to know as well. That's ok, I have to get the head-unit sorted first before doing anything else. Once yours is done you should make a video of the system. Still debating between going with door subs or using the the 10" DVC 500W RMS Rockford I have laying around.
post Dec 4, 2013 - 1:27 AM
easy ...
post Dec 4, 2013 - 2:13 PM
Box
Joined Feb 23, '12
From Warrior, AL
I guess it's just more a matter of getting over cutting holes into your door panels than anything else. tongue.gif So when should the subs be in?
post Dec 4, 2013 - 2:16 PM
toyota123
Joined Jan 13, '12
From Georgia
I have done this as well its absolutely nerve wracking. I was so scared of messing it up on the first one but the second was a cake walk. Just plan it out and have some patience. It's really not that hard
This post has been edited by toyota123: Dec 4, 2013 - 2:16 PM
97 Celica GT liftback DD/ project
96 corolla back up DD
post Dec 4, 2013 - 9:40 PM
see there is a trick!!!
its already has area to insert the screws. so you insert the screws, and the speaker will indent the plastic. it guides you to cut where u need.
this is after i drilled holes for the speaker grill.
post Dec 5, 2013 - 3:27 PM
Lookie here.....
post Dec 5, 2013 - 3:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Dec 5, 2013 - 3:57 PM
BEnefits of amazon prime, and 2 days shipping. Plus i contributed to site, too bad i have to work tonight, otherwise id be putting them on tonight...
post Dec 5, 2013 - 5:06 PM
Box
Joined Feb 23, '12
From Warrior, AL
Call in sick. *cough cough*
post Dec 6, 2013 - 8:29 PM
Lol it does not fit... So now ? Make it fit.
Screws don't align and terminals are on the way
post Dec 7, 2013 - 11:33 PM
toyota123
Joined Jan 13, '12
From Georgia
Had the same problem with my JL 's I was in too much of a hurry for some bass so mine aren't perfectly center as far as the logo goes but I'll probably fix that when I replace the car
post Dec 8, 2013 - 1:02 AM
Made them sucks fit. Got creative. I got some free GMAT last year from a new company. Same marterial as dynamat. Hey free is the keyword. Cant believe it takes time to apply. Anyhow do you guys think this is enough or finish all the door......
post Dec 8, 2013 - 1:56 AM
The_enD
Joined Apr 12, '13
From Bulgaria
For vibration and resonance, coverage of 25% is enough. You are wasting material.
A good read, if you want to get the car silent.
http://www.sounddeadenershowdown.com/
post Dec 8, 2013 - 10:22 AM
Got it then. Im done. But it was free and like shiny doors.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:46 AM
