3 Pages V  < 1 2 3
> 3rd Gen 3S-GE swapping information thread, Use your old harness w 2/3gen swaps?
post Jul 24, 2014 - 9:43 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (mi645 @ Jul 23, 2014 - 10:58 PM) *
its not so hard, im still curious how u managed to put a 3sgte clutch in there lol? if u have a spare 3sgte clutch maybe ill buy it to test if it works for the E56
Now I have a spare pressure plate from a 5SFE and a friction disc from a 3SGTE (21 spline).
Anyone have any vacuum diagrams that they could throw up quick for me?
Still having issues with the swap.
Car starts, and idles great. Very smooth. But at 3k RPM it sputters, misfires and backfires. frown.gif
Timing is good, 10 degrees with check connector bridged. Firing order correct - spark plug wires are all good. If you unplug each one of the wires it definitely changes the way the engine runs, so it is idling on all 4 cylinders. We had to take the timing belt off to deal with an oil leak, and it had the same misfire before and after. I triple checked the cam timing when the belt went back on.
No codes, even when I try the diagnostic mode. the CEL will flash when it misfires and hits this weird 2500 - 3000 RPM rev 'limit' but no codes are thrown. It will drive the wheels in 5th (car is on a hoist) so it runs fine under load, but has the same stumble/rev limit at 2500/3000.
Also loud backfiring out the exhaust, and the intake vacuum 'pulses' to atmospheric when it hits this rev limit. Plug gaps are fine but plugs are a little black. Seems like an ignition problem? Has new plugs, cap and rotor. Was going to try an igniter/coil assy from a known working ST205, also different plug wires. We also have another ECU to check with.
It runs beautifully right up until you hit this weird rev limit/misfire point. Starts right up, idles nice and smooth.
Any other ideas?
Going to try my other spark plug wires and my MR2 ECU on Monday.
Checked the TPS sensor, coil, and ignitor - all good. 90% of the parts are brand new.
I have a feeling about the wires, as I recall feeling a significant break in the #4 cable, but didn't really think anything of it when I installed it. I also want to check my vacuum lines because the ACIS is exhibiting an odd behaviour too ( I think )... and my fuel pressure VSV broke when putting the engine back into the bay. Snapped a nipple off in the hose.
This post has been edited by KAOS: Jul 24, 2014 - 9:43 PM
post Jul 24, 2014 - 10:56 PM
Kev6GCTH
Joined Jan 26, '14
From Thailand
In my past experience, low rev limit was came from you use wrong part no. of ignitor.
post Jul 25, 2014 - 2:14 AM
mi645
Joined May 23, '12
From northridge,CA
use 5s igniter and coil. ad map sensor they r the same just to test it.
post Jul 25, 2014 - 9:55 AM
KAOS
Joined Apr 18, '06
QUOTE (mi645 @ Jul 25, 2014 - 1:14 AM) *
My 5s didn't have a coil... just the ignitor.
post Jul 25, 2014 - 4:41 PM
mi645
Joined May 23, '12
From northridge,CA
my bad i meant just the igniter
post Jul 26, 2014 - 6:39 PM
Rusty
Joined Nov 5, '07
From New Zealand
My thoughts are on the igniter being faulty, what is your vacuum piping set up btw, some people can get some lines mixed up too
post Jul 26, 2014 - 6:57 PM
KAOS
Joined Apr 18, '06
We took a known working igniter and coil and had the same result.
I'm leaning more towards the spark plug wires or the distributor.
post Jul 26, 2014 - 7:52 PM
Rusty
Joined Nov 5, '07
From New Zealand
Whats the spark like?
post Jul 27, 2014 - 1:27 PM
KAOS
Joined Apr 18, '06
QUOTE (Rusty @ Jul 26, 2014 - 6:52 PM) *
seems ok on startup, pulled each plug out during idle and the plugs are firing, but havent tested under load, which is when the backfiring happens... kindasad.gif
post Aug 1, 2019 - 12:23 PM
marco2002
Joined Jul 1, '19
From Virginia
Bout to install new Red top Beams . Engine comes with harness and ecu. But does not come with air intake hose or air box or MAF. Can I use the air intake hose and air box off of my existing 5SFE ? I plan to purchase new MAF
post Aug 4, 2019 - 11:51 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (marco2002 @ Aug 1, 2019 - 11:23 AM) *
The BEAMS has a much larger throttle body and totally different intake lid than the 5S, and the MAF housing is built into the lid of the airbox so unfortunately none of the 5S stuff will work. The bottom half of the 5S intake box is the same so that part can be used again but you'll still want a BEAMS intake lid and elbow.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 29th, 2024 - 8:53 PM
