> my first car, celica info needed
post Dec 17, 2013 - 1:02 AM
hector_39
Joined Dec 17, '13
From metairie LA
whats up guys, so im about to buy a 1995 toyota celica gt convertible and i was wondering what you guys think about it? i read some reviews and they say that the parts are too expensive. also, where could i get a jdm engine for it to upgrade and how do i know if it fits or not, im a car lover and i want to start learning since im just 16 so i need help from you guys. thanks
post Dec 17, 2013 - 7:19 AM
rentaspace
Joined Sep 23, '12
From Australia
Basically, engine wise you have these options:
- 1.8L 7AFE
- 2.2L 5SFE
- 2.0L 3SGE
- 2.0L 3SGE "BEAMS"
- 3SGTE
These are the 'stock' engines found in 6th gen Celica's. All these engines will fit all 6th gen celica as they use the same/similar engine mounts.
That being said, I am pretty sure the 3SGTE requires a GT4 hood to fit and allow the airflow for the topmount, but this engine will fit into a modified standard bonnet if you use a FMIC instead.
Depending what engine your car has in it, A 3SGE 'BEAMS' is a good upgrade from a 5SFE or a 7AFE. It revs higher, is more fuel efficient, has VVT-i and more powerful. The BEAMS model 3SGE is very easy to spot over a normal 3SGE as the BEAMS has a REDTOP:
If you want all out power, then the turbo 3SGTE is the way to go, but it will cost more to maintain and as mentioned above, will require a new hood or a FMIC.
Personally, if you have the 7AFE or 5SFE, then look for a 3SGE BEAMS Redtop. It is a great all-rouder NA engine and will drop straight into the engine bay. smile.gif
post Dec 17, 2013 - 8:03 AM
hector_39
Joined Dec 17, '13
From metairie LA
Thank you, I really appreciate it
post Dec 17, 2013 - 2:06 PM
richee3
Joined Jun 29, '08
From Denver
The 3S-GTE fits under a stock hood with no problems. It just retains more heat than the GT4 hood.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 17, 2013 - 2:19 PM
enderswift
Joined Jul 12, '08
QUOTE (richee3 @ Dec 17, 2013 - 2:06 PM) *
I wouldn't quite say no problems. It works, but my gte needed 1.5" spacers on the hinges and trimming of the webbing underneath to clear the intercooler and intake box properly. otherwise you'll be rubbing and scraping stuff
This post has been edited by enderswift: Dec 17, 2013 - 2:21 PM
post Dec 17, 2013 - 3:21 PM
Rusty
Joined Nov 5, '07
From New Zealand
Gen 3 3S-GE not a Gen 1 3S-GE wink.gif and don't forget the 3S-FE and 4S-FE 1.8L on some Curren's too
post Dec 17, 2013 - 4:09 PM
QUOTE (enderswift @ Dec 17, 2013 - 3:19 PM) *
Correct.
post Dec 17, 2013 - 5:04 PM
richee3
Joined Jun 29, '08
From Denver
1998 Celica GT-
BEAMS Swapped.
post Dec 17, 2013 - 8:22 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
QUOTE (hector_39 @ Dec 17, 2013 - 2:02 AM) *
Performance options aside, Be Careful (picky) when buying a 20 year old convertible. lots of people just don't know how to not tear shtuff up. restoring a torn up ragtop is lots of money.
I personally prefer the liftback, but the convertible can be nice if you be sure and take a good look at it, check for rips n tears, leaks, open and close properly ect.
Bust a Deal; Face the Wheel.
post Dec 17, 2013 - 11:22 PM
hector_39
Joined Dec 17, '13
From metairie LA
Thanks for the advice and he just changed the top, and he lives close to me and is very close to my dad so he wouldn't rip me off like that
post Dec 17, 2013 - 11:35 PM
QUOTE (richee3 @ Dec 17, 2013 - 4:04 PM) *
Where are you standing, if you are outside, then you are outstanding .... biggrin.gif
post Dec 18, 2013 - 12:31 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
There are a couple v6 options too
94 st hatch my daily driver
n
post Dec 18, 2013 - 7:33 AM
rentaspace
Joined Sep 23, '12
From Australia
Really anything is possible with enough $$$$
This post has been edited by rentaspace: Dec 18, 2013 - 7:33 AM
Lo-Fi Version Time is now: November 23rd, 2024 - 3:44 AM
