Enthusiast Joined Dec 7, '13 From Spring8 Currently Offline Reputation: 0 (0%) ![]() |
Need to get the head of my 1994 celica gt as I droped a screw bit down the air intake n it's now possibly sitting on the piston how do I take he head of to get to it . Picks and detailsplz
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
if you dropped a screw down there, it might be sitting on top of the valve. if it got past the valve, remove the spark plug, rotate the crank so that piston is at BDC and stick a small magnet in there
This post has been edited by Smaay: Dec 17, 2013 - 6:39 PM -------------------- 2001 Celica GT-S Turbo
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) ![]() |
Probably at the bottom of the intake, remove the intake and start searching there.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) ![]() |
You can buy the stick magnet. You can manually turn the crank until it drops into the valve and use the magnet to pull it out of the spark hole.
Flexible magnet stick can be found at Any auto store.......I however doubt that any socket would fall past a valve....you're more likely to get it jammed and bent your valve.
However if its on a piston already remove sparkplugs and retrieve with magnet Remove your intake manifold and retrieve it..this is the proper way This post has been edited by playr158: Dec 18, 2013 - 12:55 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:04 AM |
