Closed TopicStart new topic
> FS: Celica Project / Parts car and lots of spares - West Michigan &a, COMPLETED
post Dec 21, 2013 - 10:45 AM
scothaniel
Joined May 1, '03
From Michigan
1996 25th Anniversary Edition Celica Project / Parts car - West Michigan $3000 OBO
Drives but needs work and I just don't have the time or energy to do it. Have some lingering issues after a slide-off into a curb and there's a bad exhaust leak that keeps returning.
The car is silver with black cloth interior. The exterior has a few scrapes and needs some touch-ups but is good overall. Interior is worn, mostly driver seat and driver side carpet. ST205 hood and bumper.
The motor is a 3rd gen 3SGE converted to turbo (pistons and minor head work). The motor was built by C-Tech Performance in Grand Rapids (http://c-techperformance.com/).
Details:
3rd Gen Head and Block
Turbo pistons
ST202 side-feed intake manifold w/ ACIS disabled (ACIS creates havoc under boost)
Top-feed fuel rail with 550cc injectors
Custom (cracked) exhaust manifold with Mitsubishi Evo 8 TD05-HR-16G turbo and 02 housing
Custom stainless exhuast and muffler (Lenger Racing)
Newer timing belt and ST205 head gasket (less than 8K miles)
Spearco W/A intercooler, ST205 ic radiator, newer Bosch water pump
Tial BOV
E153 Transmission
ST205 ECU (no code 54)
ST205 calipers/rotors modified to fit st202 hubs *** see below
Rear disk brake conversion
KYB rear struts
Rear strut tower brace
Koyo radiator
3 Excellent Rims & Tires, 1 with minor damage to rim.
New control arms, ball joints, tie rod ends and end links
New AC condenser / radiator
Spare parts:
3rd gen 3SGE block and head
new Denso (supra) fuel pump and resistor pack - planned to switch back to std low/high fuel pump operation
Complete Superstrut front suspension, hubs, subframe, but bad Fig 8s.
ST205 center diff, driveshaft, ST185 rear diff and subframe (big dreams)
2-Post wing
ST202 front bumper
ST205 exhaust manifold
Incomplete Turbo kits:
#1: ST205 exhaust manifold with port for Tial WG
T3 Adapter,
Greddy / Mitsubishi TD06H 20G turbo - fresh rebuild
* Needs downpipe to be complete
#2 Custom stainless manifold with TD05 adapter
Mitsubishi TD05H-14B turbo
Evo 3 O2 housing
* Needs lower downpipe to be complete
The Bad:
Needs front passenger side ST205 rotor and pads - accident pushed rotor into ball joint, gouging it badly and causing a loud squeal. New rotor shipped from UK is $150. Pads are the same as the Surpa TT.
Needs alignment
Needs clockring - no cruise, horn, and possibly airbag!
Bad valve tick while idling, hasn't gotten worse or better over the past 3 years
Bad exhaust leak - appears to be a cracked manifold.
Bad A/C drier. Have new part, needs to be installed and A/C recharged
Bad antenna
Bad rear defrost
Will post pics later today.
This post has been edited by scothaniel: Jan 6, 2014 - 8:13 AM
Scott
West Michigan
post Dec 21, 2013 - 4:12 PM
scothaniel
Joined May 1, '03
From Michigan
This post has been edited by scothaniel: Dec 21, 2013 - 4:17 PM
Scott
West Michigan
post Dec 22, 2013 - 1:37 AM
Price is 3000k for all? Or just car, does it include all the extra stuff?
Under the car is it rusty, rusted or cancerous ? Pics by any chance..?
post Dec 22, 2013 - 1:53 AM
Do you have interior pics?
post Dec 22, 2013 - 8:59 AM
scothaniel
Joined May 1, '03
From Michigan
$3K for everything, car and spare parts.
I'll take pics of the interior and undercarriage today. No real rust that I know of.
Here's the wheel damage - looks like the rim protector on the tire sheered off, which should be covered under road-hazard so I can probably get it fixed this week.
And the driver side seat, which is the worst of the interior wear:
Scott
West Michigan
post Dec 22, 2013 - 5:48 PM
scothaniel
Joined May 1, '03
From Michigan
Interior pics - needs a good cleaning
(no spare)
indention from kids car seat, should go away in day
small hole in driver side floor mat
elbow dent in pass side door panel
Scott
West Michigan
post Dec 22, 2013 - 5:52 PM
scothaniel
Joined May 1, '03
From Michigan
Underside pics. Found rust on driver side door and struts
Drive side door rust
Pass side looks good
Scott
West Michigan
post Dec 23, 2013 - 3:39 PM
scothaniel
Joined May 1, '03
From Michigan
Some of the spare parts:
20G
TD05-14B
ST205 manifold w/ TD05 adapter
3rd gen block/head
Scott
West Michigan
post Jan 5, 2014 - 9:25 AM
Tomscelica
Joined Jan 5, '14
From Long island, NY
QUOTE (scothaniel @ Dec 21, 2013 - 4:12 PM) *
Looks like a good celica. Did this car sell? Its what im looking for.
post Jan 5, 2014 - 2:44 PM
scothaniel
Joined May 1, '03
From Michigan
There's a buyer. Will post again if it goes through or falls through.
Thanks!
Scott
West Michigan
post Jan 6, 2014 - 8:08 AM
scothaniel
Joined May 1, '03
From Michigan
SOLD!
Scott
West Michigan
Lo-Fi Version Time is now: November 29th, 2024 - 7:06 PM
