Wiring four headlights |
Dec 26, 2013 - 12:09 AM |
Enthusiast Joined Dec 5, '13 From Bend, OR Currently Offline Reputation: 0 (0%) |
Is there any way to wire all four headlights to come on, so you can flick between high and low, but all 4 are on at all times?
Tried searching the forum but nothing is written on it. thanks (: |
Dec 26, 2013 - 3:39 AM |
Enthusiast Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) |
Why would you have long beams on at all times?
Rally thing? -------------------- |
Dec 26, 2013 - 5:28 AM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
You could wire a daylight circuit that will lit up the high beams at a lower %. Maybe you can then wire directly to your low beams and use their power source or use a relay to trigger to whole thing. But you might be fine wiring directly since it won't consume that much power especially if you are you using HIDs.
This post has been edited by The_enD: Dec 26, 2013 - 5:28 AM -------------------- |
Dec 26, 2013 - 5:57 AM |
Enthusiast Joined Mar 1, '10 From TX Currently Offline Reputation: 16 (90%) |
you could switch you hi beams to h4 bulbs then make a couple of harness modifications to double the plugs on your low beam harness, and convert your hi beam harness to fit the alternate pin pin the h4 bulb.
that way your light switch wont need any modifications, and it'll function like normal only with 4 low beams and 2 hi This post has been edited by JasonTX: Dec 26, 2013 - 5:58 AM -------------------- JN 3:16
Dec 26, 2013 - 11:01 AM |
you could switch you hi beams to h4 bulbs then make a couple of harness modifications to double the plugs on your low beam harness, and convert your hi beam harness to fit the alternate pin pin the h4 bulb. that way your light switch wont need any modifications, and it'll function like normal only with 4 low beams and 2 hi Exactly, I'm doing a halo light conversion with ballasts but i want all four on as low beams, then be able to switch to high beams at any time. do you have a wiring diagram? |
Dec 26, 2013 - 12:56 PM |
That won't happen without serious modification. The high beams use a 9005 bulb which is a single filament bulb, meaning it is only intended to put light out where the headlight housing aims it unlike a dual filament bulb which has a headlight housing designed to aim the light to different places depending on which filament is illuminated. The Celica's headlights were designed to only direct the light from each housing to one place, and changing bulbs won't change that fact.
You can imitate a DRL setup which will keep the high beams on at half power, but regardless you will still be aiming your high beams up into oncoming traffic which is downright dangerous and illegal, half power or not. Daytime running lights are safe during the day, but still blinding at night to other drivers. The only way to actually do this safely would be to replace all four bulbs and headlight housings for a dual filament setup. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Dec 26, 2013 - 2:08 PM |
Convert to quad projectors, with the type that is both high/low beam in one projector, that switches by changing the cut off.
Dec 26, 2013 - 5:27 PM |
Convert to quad projectors, with the type that is both high/low beam in one projector, that switches by changing the cut off. do you have a link for where i could get these at? That won't happen without serious modification. The high beams use a 9005 bulb which is a single filament bulb, meaning it is only intended to put light out where the headlight housing aims it unlike a dual filament bulb which has a headlight housing designed to aim the light to different places depending on which filament is illuminated. The Celica's headlights were designed to only direct the light from each housing to one place, and changing bulbs won't change that fact. You can imitate a DRL setup which will keep the high beams on at half power, but regardless you will still be aiming your high beams up into oncoming traffic which is downright dangerous and illegal, half power or not. Daytime running lights are safe during the day, but still blinding at night to other drivers. The only way to actually do this safely would be to replace all four bulbs and headlight housings for a dual filament setup. Is there some type of modification to lower them and raise them at will? Or is there any car that does this |
Dec 26, 2013 - 9:16 PM |
Bi Xenon are the type of projector that is both HI/low bean in one bulb/housing. it raises the cutoff at will by energizing a solenoid. you will have to do the retrofit yourself, but you will end up with 4 low beams, and 4 hi beams, when needed. they all use a SINGLE bulb per housing, so only needs 4 bulbs/ballasts which will help simplify wiring and reduce cost.
This is something I wanted to do as well. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Dec 26, 2013 - 9:23 PM |
Stephen is the man when it comes to this stuff.
Dec 27, 2013 - 4:32 AM |
I don't know if OP is ready to spend ~$600-700, but I don't see anything wrong with running the high beams at a lower voltage. It will not look as there are four identical lights and may start to blind oncoming traffic at midnight, but it's going to be cheaper.
Lo-Fi Version | Time is now: November 29th, 2024 - 2:51 AM |
