> Interior courtesy light
post Dec 28, 2013 - 11:16 AM
Mumpy
Joined Dec 22, '13
From Haverfordwest
Hi
I hope someone can help me, just got my first Gen 6 GT and my Interior courtesy light doesn't work at all, whether it is switched on or not. Both filaments look serviceable and the fuses look like they are all good also. In addition to this my ciggy lighter ring doesn't illuminate. Both the lights on the doors also do not work when opened. The speedo lights work as do the heater control lights, so my thinking is that it may be the items themselves but that's a lot of bulbs to go.
Many Thanks
Mumpy
post Dec 28, 2013 - 2:55 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Does your cigarette lighter have power? Not the light, but the plug itself. The dome light and cigarette lighter are on the same circuit. The door lights are totally different and may just be burnt out.
post Dec 31, 2013 - 12:54 PM
Mumpy
Joined Dec 22, '13
From Haverfordwest
Hi
Thanks for the help help but I have no cig lighter just a cover, will try a phone charger and see if that works.
post Jan 2, 2014 - 2:18 AM
Jeebus
Joined Apr 21, '13
From YYC
The switch in the door sill determine whether the door is open or not. When my interior light wouldn't turn on, I checked this switch. It's covered by a black rubber cover, and the screw itself is the grounding source. In my case, I unscrewed the piece, cleaned the hole to get proper grounding connection, and put it back together.
It seems unlikely that all these bulbs would suddenly stop working or burn out together especially if the fuse is fine.
This post has been edited by Jeebus: Jan 2, 2014 - 2:19 AM
post Jan 4, 2014 - 1:55 PM
Mumpy
Joined Dec 22, '13
From Haverfordwest
Thank Guys for the help, have sorted it now it was a bit of everything.
The fuse had blown under the hood, the courtesy switch on the passenger side was not earthing and the dome light bulb has gone.
Is there a trick to the dome bulb as I have just crushed it trying to get in out?
Thanks again guys.
post May 22, 2014 - 1:53 PM
Topaz95GT
Joined Dec 17, '13
From Las Vegas
Late reply but you push in and twist, there is a metal nipple on it.
But...
Can anyone help me figure out why my dome light is SOOOO dim? Hard to see anything at night.
post May 24, 2014 - 6:56 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Dim bulb usually indicates either a bad bulb, or a bad connection. If you have a multimeter, you could check what kind of current/voltage you're getting from the socket.
post Nov 5, 2014 - 9:58 AM
finalate
Joined Aug 16, '11
From california
QUOTE (Jeebus @ Jan 2, 2014 - 2:18 AM) *
I have an st, and I took my door pannels off , and found no wiring or socket for my courtesy lights to fit into . Do these only come for the gt?
post Nov 5, 2014 - 12:05 PM
msk59
Joined May 10, '14
From Tulsa, OK
^^^ I have an ST and both door and the trunk lights works. You need to trace the wiring. Looks like someone may have removed those for some unknown reason ( I have a hatchback)
This post has been edited by msk59: Nov 5, 2014 - 12:05 PM
post Nov 17, 2014 - 1:34 PM
finalate
Joined Aug 16, '11
From california
QUOTE (msk59 @ Nov 5, 2014 - 12:05 PM) *
well my car was originally a dealer owned car that someone just drove around from Toyota. My step dad bought it and kept it completely stalk, so I don't think anyone would have taken them out. I just don't have them haha ^_^.
Lo-Fi Version Time is now: December 4th, 2024 - 4:32 AM
