rpms DROP!?!!?!?!?!?!?, Almost stalling everytime |
Dec 29, 2013 - 2:17 PM |
Enthusiast Joined Jun 8, '13 From goldsboro, NC Currently Offline Reputation: 0 (0%) |
I'm going crazy with my celica. She idles fine hot and cold. When I drive down the road or rev in neutral the rpms go up normal and come down almost and some times to the point of stalling. I have tried to drive with it but had an occurrence where I got stuck in the middle of an intersection from 3 k drops to about 300-200 rpms. i have tighten the throttle cable, changed tps, cleaned idle ac valve, changed egr vavle( pulled it off a automatic camry if that matters). what can i do next!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 29, 2013 - 7:53 PM |
Enthusiast Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
Change plugs and wires would be something to do.
Notice any cel? |
Dec 30, 2013 - 12:19 PM |
Dec 31, 2013 - 3:52 PM |
What about the idle air control valve under the throttle body?
You can disconnect the wiring harness plug that goes to it and see if the problem goes away. If it does, then you will probably have to take apart the valve, clean it, and replace the gasket. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 2, 2014 - 1:05 PM |
What about the idle air control valve under the throttle body? You can disconnect the wiring harness plug that goes to it and see if the problem goes away. If it does, then you will probably have to take apart the valve, clean it, and replace the gasket. I unplugged it and it still does it any more ideas |
Lo-Fi Version | Time is now: January 12th, 2025 - 5:54 AM |
