> Turbosmart Fuel Cut Defender, Need Help Please
post Jan 8, 2014 - 7:44 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Does anyone know how and can explain to me how to install a fuel cut ? If not can you please post a link with text on how to do it or point me in the right direction. I'd greatly appreciate it. Thanks guys.
post Jan 11, 2014 - 1:27 PM
joe, dont install an FCD if you have a 3rd gen.
most FCD's on the market are not made to work on MAP based cars, where the map sensor is the main source for the ecus fuel & timing decisions.
the only FCD that i know of that actually is made to work on a map based system is the symtech FCD.
most FCD's will lock the map sensor @ 1 voltage, IE: it just locks the map sensor at say 4.3V (not the actual #, but you get the idea). you do that in a map based car like the 3rd gen, if your lucky, the car just will run like total shiz or not run at all. worse case, you blow the motor...
post Jan 12, 2014 - 9:37 AM
Lil-Joe101
Joined Dec 7, '07
Oh wow, alright. Thanks Manny, glad you gave me the info before I installed it. Last thing I want is to mess up my engine. Thinking back at it now, I can't really find to many reasons to run more than 12 pounds of boost anyway. Thanks again man.
Lo-Fi Version Time is now: February 22nd, 2025 - 5:28 PM
