Spark Plugs and wires |
Jan 11, 2014 - 6:07 PM |
Enthusiast Joined Jul 23, '13 From Marlborough, MA Currently Offline Reputation: 0 (0%) |
ngk plugs are what i get usually but for wires ive seen different ngk wires on these forums. Like heavy duty ones, the regular blue line ones. Whats more recommended to get. Any input is good Thanks
Jan 11, 2014 - 6:54 PM |
for your stock 7A...stock wires.
If you dont like that answer and just want some wires to spruce up your engine bay, go with the regular blue ones, no need for large heavy duty wires, there wont be any benefit in your case -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 11, 2014 - 9:44 PM |
The Denso TT series of plugs are good and cheap. Probably takes the PK20TT....like almost every other car ever.
Jan 11, 2014 - 11:08 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Chances are the leads don't even need replacing, why? Its not a moving/wearing part. You can test the resistance to see if they're in factory spec with a voltmeter.
Or as Tigawoods said, replace to spruce up the engine bay. -------------------- |
Jan 11, 2014 - 11:49 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
on www.rockauto.com
Denso TT plugs $2.30 ea http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307 Denso wires $29 http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307 or the NGK $34 (even in blue) http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307 either of these are stock quality. the ones that say "5mm" like these are unnecessary with a stock ignition system http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307 but they are still only $10 more /shrug if you go to your local autoparts store they will stick you good for them. pretty sure Denso is what they have from the factory. the Toyota motor manual says they can have up to 25,000 ohms with the wire including the dist cap. to me this seems obscene, especially when brand new ones are like 1,000 ohms. Over time the heat and grease in the engine bay will break down insulation on the wires, if they are more than 50,000 miles or so they can foul, more likely from the outside-in. be sure and replace the dist cap and rotor while your at it. It won't make your motor more powerful than it already is but - in the past I have had a car not run right, jerking, stalling, dying, and then I spent $200 to take it to a shop just to have them tell me it needed plugs and wires : | and I would argue that although the wires are not "moving" millions of the little bitty electrons are zipping through the copper conductors each second. -------------------- Bust a Deal; Face the Wheel.
Lo-Fi Version | Time is now: January 10th, 2025 - 1:30 AM |
