10 Pages V  < 1 2 3 4 5 > »
Closed TopicStart new topic
> Close - 96 ST anniversary edition, Story has ended. Car is now sold.
post Feb 4, 2014 - 1:26 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Wow. What size socket did you use to press out the sleeve?
And how did you damage the press like that?
~bloodMoney
post Feb 4, 2014 - 2:33 PM
lol, it was a 24 mm, i should have used a 25 mm or 26mm. I just opted not to get one. (i should have) . The press is a harbor freight press, and their reviews are bad in a way, i guess i expected for it to happen. But not that fast. the damage happened before i figured out to cut the sleeves, then heat them and press them.
I tried to press the sleeves from the get go, and it was not possible, they were seized so bad, i guess too many winters...
its been 1 1/2 week donwtime, since weather, work and waiting for parts. I should have planned this different, but i have a daily driver.... and the vert still drivable, although missing most of the interior now.
post Feb 4, 2014 - 3:09 PM
cheela
Joined Feb 2, '07
From Berlin, WI
are any of your cars ever in one piece? lol!
keep up the good work Berto.
post Feb 4, 2014 - 3:26 PM
as a matter of fact, no! LOL, its a baaaaad habit!....
post Feb 4, 2014 - 6:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hey, we have matching seats. Your car is a much nicer colour though.
2001 Miata LS 5-speed
post Feb 4, 2014 - 11:19 PM
scothaniel
Joined May 1, '03
From Michigan
Fantastic work! Glad its getting the care it needed.
Scott
West Michigan
post Feb 5, 2014 - 12:32 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
lol welcome to my world. I have 5 cars and only 3 of them run. All-trac still needs paint and engine re-installed. Supra is making a funny noise
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 5, 2014 - 3:14 AM
i know, its bad, bad...
1973 corona, bad carburator and needs carpet changed...
1976 celica on rotisserie chassis only
1978 corolla, not running burned harness
1996 celica, no rear suspension
1997 convertible no interior.
1983 honda motorcycle, in a box.... lol, i have not done the frame yet...
i literelly have minimal space in garage, and also rent a 10x40 storage room....
so people dont beleive when i wont modify the STI, i just wont...
post Feb 9, 2014 - 1:01 PM
Fate
Joined Nov 30, '04
From Atlantic City
QUOTE (Ted95 @ Feb 2, 2014 - 11:30 PM) *
QUOTE (Fate @ Feb 1, 2014 - 6:39 PM) *
Great work as always! Is there a part number for the bolt?
From toyodiy
90901-09001 two long bolts to connect to subframe
90901-19001 two long bolts for the hubs
90179-14019 four nuts for the bolts above
Associated washers
90201-14017
90560-14022
thank you Cam!
how many washers of each though?! (being lazy)
post Feb 9, 2014 - 1:15 PM
about 4 per bolt, but if you are careful, you can reuse the ones you had.
the 90901-09001 will usually not be damaged and is the most expensive one.. its usually never rusted...
i ordered..
90901-19001 holds the spindle to the control arms..
90119-12131 for the lateral arms..
post Feb 10, 2014 - 3:50 PM
the yard, and its many surprises.. lol
got a new foam, because well
see...
and now the seat is cleaned and scotchguarded...
thats the upper section of the passenger on the driver.
went from trimming the edges
to applying some glue...
to fitting my new custom made cover...
not bad for the first time..
its been to cold to work...
post Feb 11, 2014 - 5:09 PM
seat cover has a hole...
repaired...
post Feb 11, 2014 - 11:07 PM
+1 like.
post Feb 11, 2014 - 11:11 PM
the benefits of having a sewimg machine, and knowing how to use one.
post Feb 17, 2014 - 6:59 PM
ok, i know some of you dont care, but there is a reason for all..
today i cleaned and baked cookies...
and here are them baking under heating lamp
finally got around to installing the pass seat, that was repaired...
of course after throwing new set of carpets...
my camera died, so all i have is crappy cell phone pics...
post Feb 17, 2014 - 10:29 PM
Those arms look great.
That knob has seen better days,
post Feb 17, 2014 - 10:37 PM
36 hours for paint to cure, but its chip free they say
post Feb 18, 2014 - 7:49 PM
more cookies today...
and these suckers are going for a second round of blasting.
soaking overnight with "must for the rust" which is a phosphate solution, 30 min each knuckle, and the rust was like, tough...
post Feb 19, 2014 - 7:15 PM
pulled out the big sandblaster today, what beautiful weather... 65 degrees outside...
then baked the cookie....
post Feb 19, 2014 - 7:19 PM
richee3
Joined Jun 29, '08
From Denver
I think you're burning all of your cookies. They're all turning out black.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: November 25th, 2024 - 6:45 PM
