> 96 factory alarm remote programming? please read
post Jan 20, 2014 - 6:46 PM
superman8589
Joined Nov 23, '11
From Tampa, FL
Hey, I have a 96 celica st 1.8l have had it for about maybe 2.5 years now, my car wen you disconnect battery wen u goto reconnect it the alarm goes off and to turn it off u have quickly run into car and put key in ignition.. wen I bought the car I was never given a remote nor told car was equipped with an alarm. The anti theft light isnt in my car either... but I decided go digging last night after connecting battery on again and it going off as usual and I found the shock sensor and all but no main box I think I have located it but no sure since its under the dash, i found the shocker device and where control shock level but it has plug which looks like plugs into a plastic black box ziptied to black vent...
we have a 94 celica gt as well which has alarm too but that was has factory remote and has the light as well.. and his control box is under the driver seat.. I will post pics of wat I found...
My question is wat do I do I want to get a clicker for it I have an old keyfob clicker from an old 03 sienna that I found in junkuard but every programming step I try I cant even get car going into programming mode...
Maybe im not finding correct link for it.. does anyone know correct sequence to program a remote.. and is it possible remote I have could work? And also even if no clicker is there away get it alarm to automatically turn on even without clicker and just use the key disarm it..
I will add pics as soon as I get on laptop..
post Jan 20, 2014 - 7:05 PM
firt of all, you need to know brand of the alarm. if oem or not. then you start looking for a clicker. a 03 sienna clicker may not work for you. It could be an aftermarket. if you find something that looks like an alarm, write down any numbers or name and google it, go from there.
post Jan 20, 2014 - 10:12 PM
superman8589
Joined Nov 23, '11
From Tampa, FL
It diff looks factory frolocation and all
Lo-Fi Version Time is now: November 23rd, 2024 - 3:56 AM
