> Need help, dont know whats going on, misfiring?
post Jan 24, 2014 - 9:55 AM
6GCBORO
Joined Jul 23, '13
From Marlborough, MA
So im going to start out by saying i got an ebay header for my 1.8l about 2-3 weeks ago because of the old manifold cracking in multiple spots. We had it installed but no other exhaust piping was changed. (i do have a flowmaster exhaust though, dont know if that means anything.) So i drove it for about a week all fine. obviously somewhat louder and some rattling most likely due to something being loose or hitting against the undercarriage. Then about 2-3 days ago I started it up left the house and half way on my trip, it felt as if i was driving on a complete flat. no flat but went back home and on the way it just felt as it kept being pulled back let go pulled back let go. asked the mechanic, he said change the plugs. so i did. no change. then we adjusted the timing just a bit. I dont really know anything about that so i let them do what they thought. that stop and go/flat feeling while driving went away. NOW, i will drive and obviously i know my car and the clutch but it seems that ill let the clutch out a little to fast now and it will misfire just a bit mostly at 1st and 2nd gears sometimes 3rd. only when i let the clutch out to fast which isnt fast at all since i tried going slower. But in 1st and 2nd gear it will misfire a good amount going up some small hills. once i get speed going though im relatively fine. Everything before installing the header was fine so thats why i included all that. the flat tire/pulling feel and misfiring started when we dropped into low temperatures here in new england. just some xtra info.
post Jan 24, 2014 - 10:26 AM
bsamps4
Joined May 16, '10
From Raleigh
He may have advanced your timing, and with the "exhaust" that you have it may be worth it to try running premium fuel.
post Jan 24, 2014 - 10:28 AM
cheela
Joined Feb 2, '07
From Berlin, WI
check your spark plug wires. I know when mine went bad, it would stutter and misfire as well.
post Jan 24, 2014 - 10:46 AM
6GCBORO
Joined Jul 23, '13
QUOTE (cheela @ Jan 24, 2014 - 10:28 AM) *
so try new wires?
post Jan 24, 2014 - 12:28 PM
travisxcore
Joined Mar 24, '11
From 704
My dizzy did all that the first time it went out. Check your cap, rotor, and then check the distributor out. It had chewed the primary coil up and for a bit caused me to have 1 dead cylinder before it died.
post Jan 24, 2014 - 12:54 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (6GCBORO @ Jan 24, 2014 - 9:46 AM) *
so try new wires?
how old are your wires?
post Jan 25, 2014 - 10:51 AM
6G96GT
Joined Jan 20, '08
From East Coast
Up a hill I had the exact same problem in another car. I would pop and misfire all over the place. After inspection, it turned out to be a wire with a good gash in it. We changed the wires...problem solved.
6GCBORO
Joined Jul 23, '13
wires have never been changed on the car as far as i know. odometer is at 214xxxx miles
Lo-Fi Version Time is now: January 10th, 2025 - 1:41 AM
