> My 7afe TURBO project
post Jan 24, 2014 - 3:18 PM
RoadRunner
Joined Jan 24, '14
From Bahrain
[color="#FF0000"][/color]Hi Guys ..
Iam new member in this forum and i benefited a lot after i read the topics..
in this week i will start my project in my Corolla Engine 7A-FE .. I know alot of members will suggest for me to change the engine but in our country difficult to found 3gs or others.
My goal exactly to make my car for carshow and dailyuse.
I will use RB20DET Turbo .. what do you think guys it will be ok?
And i want to ask what i will need to boost my 7a with stock internal block
NOTICE: My Transmission Automatic..!!
post Jan 24, 2014 - 5:44 PM
cheela
Joined Feb 2, '07
From Berlin, WI
search "OOBE" in the search bar in the top corner.
he is one of the first 7A automatic turbos on here.
go for it my friend.
post Jan 25, 2014 - 10:56 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
You will NEED an auxiliary transmission cooler to allow it to handle the extra power, if you can find someone who can rebuild the transmission and modify the valve body for better faster firmer shifting that would be very good as well.
post Jan 25, 2014 - 11:03 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (cheela @ Jan 24, 2014 - 6:44 PM) *
Thanks my friend .. i will search now
post Jan 25, 2014 - 11:55 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
Thanks guys ..
i send message to OOBE
Guys what about the oil i need two ways in and out to the turbo .. from where can i take?
This post has been edited by RoadRunner: Jan 25, 2014 - 12:18 PM
post Jan 25, 2014 - 12:19 PM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (Bitter @ Jan 25, 2014 - 11:56 AM) *
Thanks Dear .. i will use good cooler to the transmission i need maximum 6 to 7 PSI
post Jan 25, 2014 - 8:16 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Bitter @ Jan 25, 2014 - 7:56 AM) *
no he wont, not with low boost.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 25, 2014 - 10:03 PM
Bitter
Joined Mar 11, '06
I disagree, but that's OK.
He already lives in Bahrain, which gets rather warm in the summer and stays pretty nice in the winter.
http://weatherspark.com/averages/32754/Man...Muharaq-Bahrain
100F average summer temps PLUS a turbo ontop of an automatic transmission dumping heat into the cooling system. He'll likely want to add more cooling capacity, especially if he's running a front mount intercooler which would be dumping warmer air through the radiator. If he gets an aftermarket radiator then he HAS to run an auxiliary cooler since there won't be a trans cooler built into the radiator. Regardless of that, the stock trans cooler is mighty wimpy. Calling a cooler is a misnomer, it's a heat exchanger. It warms the fluid faster when it's cold and keeps it from getting entirely too hot later, however since heat is the biggest killer of the automatic even the 210-220 F coolant temp is a little on the high side for an auto trans. Add atop that 30-50FT/Lb's more torque to a trans that's old already and you're going to add stress and heat that maybe it can handle maybe it can't, it will work it's best at about 180F fluid temps. I suspect in the heat there with the added power he'd be seeing fluid temps north of 230 and that's where things start to degrade.
And about the valve body work, at stock power levels the A245/A246E have a slow/weak shift from 2-3 right off the bat that gets a little worse as they age. Slow shifts are slow because things are allowed to slip as they apply, slipping is friction, friction makes heat. Adding power to a slow shift will just make it slip more because of a weak apply. Correct the 2-3 shift softness and it'll help a lot. Other than that and the general compromises that Aisin makes between shift speed/firmness and comfort (which are inherent to any trans for the most part) the A24x series are solid units.
This post has been edited by Bitter: Jan 25, 2014 - 10:07 PM
post Jan 26, 2014 - 12:17 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (Smaay @ Jan 25, 2014 - 9:16 PM) *
Dear i want it for low boost .. Maximum 6 PSI for carshow and dailyuse..
Thanks for reply
post Jan 26, 2014 - 12:23 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (Bitter @ Jan 25, 2014 - 11:03 PM) *
Our weather very hot specially in summer .. But i will use it with low boost .. maximum 6 psi .. what i will need guys?
Injectors? fuel regulator? fuel pump? Blow of valve? whats else guys
i will buy the parts this days i need suggestion
post Jan 26, 2014 - 3:31 AM
QUOTE (RoadRunner @ Jan 25, 2014 - 11:55 AM) *
Thanks guys ..
OOBE won't reply...he hasn't been active in over a year.
read this:
http://www.6gc.net/forums/index.php?showtopic=8865
and this:
http://www.6gc.net/forums/index.php?showtopic=52444
post Jan 26, 2014 - 9:28 AM
Bitter
Joined Mar 11, '06
Did I miss what you're tuning it with?
post Jan 26, 2014 - 11:40 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (playr158 @ Jan 26, 2014 - 4:31 AM) *
Thanks guys ..
read this:
and this:
Thanks Playr
These are very important topics..
post Jan 26, 2014 - 11:42 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (Bitter @ Jan 26, 2014 - 10:28 AM) *
I will use apexi Super AFC
What i will need more?
post Jan 26, 2014 - 12:45 PM
Bitter
Joined Mar 11, '06
SAFC in my opinion is not sufficient, there is no timing control and very limited fuel control.
post Jan 27, 2014 - 12:24 AM
RoadRunner
Joined Jan 24, '14
From Bahrain
QUOTE (Bitter @ Jan 26, 2014 - 12:45 PM) *
If i will use it without tuning..any problem will happen? for low boost i will use it on 6psi maximum
Now i took RB20DET Turbo
Intercooler
Blow of vavle
custom manifold
i think i will need also injectors and fuel pump
post Jan 27, 2014 - 4:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Bitter @ Jan 26, 2014 - 9:45 AM) *
if its an older engine, he could turn the distributor back. That will work just fine.
RoadRunner, read some of the things I ran into http://www.6gc.net/forums/index.php?showto...;hl=7a-fe+turbo
post Mar 3, 2014 - 8:40 AM
holdmywetnutz
Joined Jan 13, '14
From pompano
Good luck on the project 7afe turbo.. they are very fast arournd 15 psi and up.. the throttle response and turbo combo on these engines jump acceleration fast..
Lo-Fi Version Time is now: January 10th, 2025 - 7:42 PM
