Closed TopicStart new topic
> 3S-FE info thread
post Jan 24, 2014 - 10:58 PM
Rusty
Joined Nov 5, '07
From New Zealand
The 3S-FE is a 16-valve 2.0L economic engine built by Toyota, the engine uses 2 camshafts, but is run by a single cam gear(pulley) with a camgear on each camshaft. It is found in the entry level Japanese Celicas such as SS-I ST202 & 4WS SS-I ST203 from 1994 to 1999, its torque band was quite suitable for the automatic models.
Engine info:
Power 140ps/138BHP/103KW @ 6,000rpm Engine. Works out roughly to 106ps/105WHP/78KW @ 6,000rpm Wheels
Torque 19kg-m/137ft.lb./186Nm @ 4400rpm
Engine displacement: 1998cc
Compression ratio: 9.5:1
Bore & Stroke: 86 x 86mm
Camshaft duration (IN/EX) - (Unknown)°/° (advertised duration) (Unknown) @ 1mm lift / (Unknown) @ 0.050in. lift
Camshaft lift: (IN/EX) - (Unknown)mm/mm
Valve diameter: (IN/EX) - (Unknown)mm/mm
Throttle body diameter: (Unknown)mm
Buckets/lifters: (Unknown)
Notes: DOHC run by single cam gear
Dynograph:
Additonal photos:
Lo-Fi Version Time is now: November 22nd, 2024 - 11:52 AM
