> rev problem, gen 3 3SGTE
post Jan 26, 2014 - 10:08 PM
ssj3timy
Joined Apr 15, '11
From Lima-Peru
hi,
Does any one know why my gen3 3sgte is revving until 5.8K-5.9K? I have changed the rotor cap, rotor, wires, spark plugs, checked vacuum, fuel pressure and every thing is normal.
My ignition mods are:
MSD SS coil
MSD 6AL 6425
MSD tach adapter
NGK wires
sparkplug IK20 (same problem)
sparkplug BKR7EIX (same problem)
New rotor and cap
There is no diagnosis code stored on the ecu and running on RON97.
http://www.youtube.com/watch?v=C9oS82K9QJ0...pEwUQlAG_mQcjFg
my 3sgte
This post has been edited by ssj3timy: Jan 26, 2014 - 10:10 PM
post Jan 26, 2014 - 10:20 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Currently Online
Check the cam timing just to make sure nothing slipped a tooth also check you're not hitting the stock fuel cut, I believe it cuts fuel if boost pressure rises over a certain amount.
post Jan 27, 2014 - 9:19 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Sounds like the rev limiter. Are you sure the 6AL rev limiter dials are set where they are supposed to be? Has it ever worked correctly? What is the history of this setup?
post Jan 29, 2014 - 1:21 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
check the cam timing. i had a similar incident in my Supra, one of the cams slipped a tooth
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 29, 2014 - 10:07 PM
ssj3timy
Joined Apr 15, '11
From Lima-Peru
the 6AL is set to 7200 rpm, also when is set to a higher rpm it doesn't matter, the cut is still on 5800-5900 rpm. besides, when I set to less rpm the 6AL cut the ignition. I think that the 6AL si operating properly. I just check the camshaft pulley and is set to the correct tooth. I was running at 12° without any problems at 15psi. so I'm going to set it at 10° and see whats happen.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:10 PM
