car died....now power windows, sunroof and gauges dont work |
Feb 4, 2014 - 1:07 AM |
Enthusiast Joined Apr 6, '12 From south carolina Currently Offline Reputation: 2 (100%) |
so my car died other night, i replaceed the alternator and put a newer batter in, so far it cranks and runs. ever since right before it died tho, i noticed the power windows, sunroof and gauges dont work. My windshield wipers work, but they are very slow. whats goin on? it has a new alternator, why isnt the windows and gauges working now?
This post has been edited by celicaluva79: Feb 4, 2014 - 1:09 AM |
Feb 4, 2014 - 1:53 AM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
so my car died other night, i replaceed the alternator and put a newer batter in, so far it cranks and runs. ever since right before it died tho, i noticed the power windows, sunroof and gauges dont work. My windshield wipers work, but they are very slow. whats goin on? it has a new alternator, why isnt the windows and gauges working now? Well a similar incident happened to my car but that was when i reversed the terminals on the battery and blow my main fuse, perhaps you've blown the main fuse have to taken a look at it? |
Feb 4, 2014 - 2:07 AM |
no i havent..i was.kinda hoping it was just a fuse....bcuz everything works exept power windows, moonroof, gauges and my wipers are slow.
Feb 4, 2014 - 6:08 AM |
check all them little things people call fuses,
check all your grounds check battery voltage, take your car to autozone to check the charging system -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 23, 2023 - 10:20 PM |
Enthusiast Joined May 30, '16 From wild 100's, South Chicago Currently Offline Reputation: 3 (100%) |
I’m having the same problem:change the alternator, turn car on , to check , I turn the head lights on ,turn radio on and put the time on the clock, then every power inside turn off; the wipers and taillights no working nor the power look .Only thing with power is the headlights ,door lights and hazards lights. ALL fuse check good,check alternator and battery wire all normal.At least turns on but it donot have brake or signal lights
Jan 19, 2024 - 12:50 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
I’m having the same problem:change the alternator, turn car on , to check , I turn the head lights on ,turn radio on and put the time on the clock, then every power inside turn off; the wipers and taillights no working nor the power look .Only thing with power is the headlights ,door lights and hazards lights. ALL fuse check good,check alternator and battery wire all normal.At least turns on but it donot have brake or signal lights I'd suggest you check the 100amp fuse. It is on the main fusebox on driver side bay. You'd have to unscrew the box because the 100amp fuse is screwed in. Back then, I accidentally shorted the system while changing the alternator. The car will start but not lights, no electricals. -------------------- God made man....
Everything else... Made in China |
Jan 24, 2024 - 10:50 AM |
yes it was that fuse.the remanufactured alternator cover on the side was making contact with the power in screw, grounding it. Error of remanufactured or maybe it got bent in on delivery travel. So that was fix ,everything is working and charge is normal , but the battery warning light stays on.
Jan 28, 2024 - 12:44 AM |
yes it was that fuse.the remanufactured alternator cover on the side was making contact with the power in screw, grounding it. Error of remanufactured or maybe it got bent in on delivery travel. So that was fix ,everything is working and charge is normal , but the battery warning light stays on. You probably shorted the alternator too. The charging system is not working. Try a different alternator. -------------------- God made man....
Lo-Fi Version | Time is now: November 25th, 2024 - 6:59 PM |
