Clutch replacements for ST, Give me options |
Jan 26, 2003 - 5:18 PM |
Enthusiast Joined Jan 26, '03 Currently Offline Reputation: 0 (0%) |
My clutch has been slipping lately and I think it's finally about to die. I need a good replacement that will last me as long as the stock clutch (110k miles) and maybe give me a little more performance. Also... one that could handle getting driven hard at times and wouldn't break after moderate use. I would also appreciate if you could provide approximate prices of the clutches and the places to buy.
PS- I have a 94 ST |
Jan 26, 2003 - 5:49 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jan 27, 2003 - 12:38 AM |
Enthusiast Joined Dec 11, '02 From Sioux Falls, SD, USA Currently Offline Reputation: 0 (0%) |
I just wish that they weren't so expensive to install, and that I had a lift so I could do it myself.
Jan 27, 2003 - 7:23 PM |
I was wondering if the clutch on this page would fit my 94 ST.. the 365+1221, which is the first one on the list. It says "Centerforce 1 Clutch Disc And Pressure Plate Upgrade (30% increase in holding capacity) - 7 AFE 1.8L Engine - from 9/93" so I was wondering if it came with everything needed to replace my stock clutch. The reason I'm asking is because im not positive and $250 is a lot of money for me to come up with... which I wouldn't want to go down the drain. I know the labor will be double that, but I have to buy the clutch first and then save up for the cost of the labor.
Sorry for posting so much but I need to be 110% positive ! This post has been edited by Phan: Jan 27, 2003 - 7:23 PM |
Jan 27, 2003 - 10:07 PM |
yepp. should fit perfect
Feb 3, 2003 - 5:33 PM |
Enthusiast Joined Aug 30, '02 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
That clutch will fit fine. However, I have a Centerforce - all it comes with is the two plates - you need to buy the alignment tool and throw out bearing separately - but in the long run it's worth it. Plus it'll only cost about $50 extra max (unless you get the bearing from the dealer - which I don't advise). The clutch itself rocks.
This post has been edited by CeliBria: Feb 3, 2003 - 5:34 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:56 PM |
