> 5sfte vs 3sgte, So I've been thinking...
post Feb 6, 2014 - 1:38 PM
yfn16
Joined Mar 5, '08
From Knoxville, TN
So I've been thinking. I'm about to tear down my current 5s motor again. Up till now, I've just been planning on keeping the block and head the same... But I've been tempted to give into peer pressure and go ahead with swapping some parts around. So here's my question:
5sfe block with 3sgte head vs. complete 3sgte motor
Which is the winner in your opinion? Any pros and cons of going one way or the other?
As always... -thanks
This post has been edited by yfn16: Feb 6, 2014 - 2:23 PM
post Feb 6, 2014 - 2:14 PM
Rusty
Joined Nov 5, '07
From New Zealand
no such thing as a factory 3S-fte head, the fe head doesn't give you extra power. for that you need a ge/gte head a 3rd gen 3s-ge head will give you more than a 3rd gen 3s-gte head.
Refer to one of the latest podcasts as it discusses the idea of 5sgte vs swapping 3sgte.
post Feb 6, 2014 - 2:26 PM
yfn16
Joined Mar 5, '08
From Knoxville, TN
Yeah. That was a typo. thanks
QUOTE (Rusty @ Feb 6, 2014 - 2:14 PM) *
post Feb 6, 2014 - 2:34 PM
Rusty
Joined Nov 5, '07
From New Zealand
http://www.6gc.net/forums/index.php?showtopic=89817
post Feb 6, 2014 - 3:15 PM
yfn16
Joined Mar 5, '08
From Knoxville, TN
Anyone have written info or links I can read? I've been listening to the pods and haven't found it yet. I'll keep listening though
post Feb 16, 2014 - 6:13 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Rusty @ Feb 6, 2014 - 9:14 AM) *
Rusty do you have more details on how a "3sge head will give you more than a 3sgte head"? The reason I'm asking is I'm running a 3sge head with stock turbo cams/springs. (machine shop killed my head and bought me a 3sge head). Are you talking about a stock 3sge head with stock internals? I know the stock 3sge intake cam has a longer duration, but I think a smaller lift, or vice versa..I don't remember. And springs compress at 40psi while turbo springs compress at 80 psi (I tested this).
This post has been edited by match220: Feb 16, 2014 - 6:19 AM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Feb 18, 2014 - 2:13 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
something I have learned in my quest for a good engine combination. if you want to use a 3S-GTE head, you need to use the 3S-GTE distributor and thus need the ECU. the diameter of the distributors are quite different between the 5S and 3S.
im looking at building a 5S block with 3S-GTE head and use all 3S electronics. im considering dropping this engine in my All-Trac in a FWD configuration to test it.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: January 11th, 2025 - 1:24 AM
