> Ebay Turbo Kit 5F-SE, I'm just wondering if anyone has used one of the all-inclusive kit
post Feb 7, 2014 - 1:44 PM
sandusky1977
Joined Oct 3, '10
From Lansing, MI
I was surfing around for a header for my 5f-se, and came across rediculous deals on these kits. I'm assuming it's because they are a total piece of junk, however, I figured I would post up and see if anyone has installed one of these.
http://www.ebay.com/itm/350868465407
I'm still leaning toward the 1mz swap myself, but maybe to keep me entertained until then I could add this,
post Feb 7, 2014 - 2:30 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Contrary to popular belief SOME of the cheap turbos sold on ebay are good quality. I had a supra friend push 24 psi on one for over a year and then he took to it off it go bigger. Obviously not ALL ebay turbos are kits are good quality, but some can be.
post Feb 7, 2014 - 5:59 PM
yellowchinaman
Joined Aug 11, '08
From London
Some can be good. But just looking at the design of the manifold puts me off.
post Feb 7, 2014 - 8:35 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Cheap, fast, reliable.
Pick 2.
My Celica!
post Feb 7, 2014 - 9:14 PM
sandusky1977
Joined Oct 3, '10
From Lansing, MI
QUOTE (jordisonjr @ Feb 7, 2014 - 9:35 PM) *
Pick 2.
Sometimes I forget the golden rule.. oh so true...
post Feb 7, 2014 - 10:53 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
ya I've seen a bolt on Supercharger kit for the 5sfe and they wanted $6000+ for it kindasad.gif
Bust a Deal; Face the Wheel.
post Feb 8, 2014 - 9:04 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
If the tubing,I/c an manifold are decent enough that not a bad deal even if the turbo is crap
94 st hatch my daily driver
n
post Feb 8, 2014 - 10:23 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
'though I think the real problem, which I've seen in several threads around here is that the 5sfe isn't really built strong enough to take much turbo abuse.
unless you want to take the thing apart and put race components in the bottom n such. which after all I've read about the beams swaps, you just as well
go ahead and put the 6cyl in it's probably easier. but if you're just looking for cheap thrills in the mean-time, and you've got money to play with wth you can another 5sfe down at pick-n-pull for $500
This post has been edited by VavAlephVav: Feb 8, 2014 - 10:27 PM
post Feb 8, 2014 - 10:50 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (VavAlephVav @ Feb 8, 2014 - 9:23 PM) *
which after all I've read about the beams swaps, you just as well go ahead and put the 6cyl in it's probably easier.
Not by a long shot. smile.gif The BEAMS is as easy as a swap gets.
The 5S is actually a very boost-friendly motor, but tuning is an issue. I agree with with all of the above, if the end goal is a V6 or any other engine swap and you know when it will happen, then the turbo kit would be a good bit of fun. If I remember right, Manny used an Ebay turbo for his 5S-FTE, but even if he didn't I know several other members here have and had decent results.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 9, 2014 - 9:33 AM
that particular "kit" is junk. manifold is horribly designed, piping and couplers are gonna be TOTALLLY usless.
only thing i'd use from that kit would be the turbo, and that would only be after a thorough inspection.
post Feb 9, 2014 - 12:55 PM
a wise man said. "you get what you paid for"...
post Feb 10, 2014 - 8:27 PM
Syaoran
Joined Jan 4, '12
From US
The best ebay manifold is the cast iron one for the 3sgte. It'll hold up to best. Don't use the external wastegate port on it. Dumping exhaust off just 1 runner doesn't make for a reliable boost control setup.
eBay turbos are good if you know what you're getting yourself into beforehand. All eBay T3/T4 turbos should be opened, inspected, cleaned if need be and, if you want peace of mind, all internals replaced with garrett internals. For added insurance you should take it to have it balanced, even though most of these come balanced already. By the end of it all it'll still be cheaper than an upgraded CT26 or a "geniune" one (I used that word loosely since eBay t3/t4 really are just low-cost, old-design garrett turbos)
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Feb 10, 2014 - 8:39 PM
sandusky1977
Joined Oct 3, '10
From Lansing, MI
Well with sound advice, I'm leaning towards spending my money on the v6 parts instead for now.
My 94 hopefully will start the swap in the spring when I can get time in my brothers shop, and the dd stays bone stock. I was thinking of the turbo setup on my 99, but with only 97k miles probably should leave it factory for now.
Lo-Fi Version Time is now: December 2nd, 2024 - 10:04 AM
