> FS: 3rd gen 3SGE Curren motor SOLD, SOLD
post Feb 9, 2014 - 12:59 AM
scothaniel
Joined May 1, '03
From Michigan
3rd gen 3SGE motor that was used for spares and mock-up of a couple custom turbo kits.
The head is was ran in one of my Celicas for around 2 years until it was swapped out for a ported head.
Includes: Valve train, gears, camshafts - untouched since the head was pulled - all 3SGE parts.
Top feed fuel rail and stock 3SGE injectors (295cc - I ran 550cc injectors without problems).
Side feed intake manifold with throttle body - ACIS may be welded shut as it created havoc under boost.
valve cover, alternator bracket and hangers present, alternator
Extra bosses have been drilled / tapped to match the turbo exhaust manifold
coolant elbow is either from a Curren or Celica.
The block appears to be in good shape; no obvious signs of problems. I pulled the lower oil pan off and everything looks like the factory original parts.
Includes: Rods / Crank / pistons
Oil pump / oil pans / oil pickup
Water pump / lines / thermostat housing
- There's no power steering pump and the pulley on the A/C pump was mangled during shipping.
I travel to Chicago quite often and occasionally to Detroit, so I can deliver / meet in this area to avoid shipping. Otherwise will need to be sent via freight. Will post pics later today.
This post has been edited by scothaniel: Mar 20, 2014 - 10:26 AM
Scott
West Michigan
post Feb 9, 2014 - 7:50 AM
eMrock32
Joined Jan 27, '14
From Fort Wayne IN
Pm'ed
94 Teal GT-DD 223,915 miles SOLD
99 WHT GT- Race car! Or just AutoX Car getting rebuilt then susp and turbo!
post Feb 9, 2014 - 9:34 AM
scothaniel
Joined May 1, '03
From Michigan
With custom td05 turbo kit :)
Scott
West Michigan
post Mar 9, 2014 - 7:21 PM
7afecelica
Joined Sep 16, '10
From Warren, MI
Which part of Michigan are you from?????
post Mar 10, 2014 - 7:48 PM
scothaniel
Joined May 1, '03
From Michigan
Currently Grand Rapids
Scott
West Michigan
Lo-Fi Version Time is now: November 30th, 2024 - 4:06 AM
