> Can someone with a GT-Four hood take a few measurements?
post Feb 13, 2014 - 8:05 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Ok, I need these to measurements.
And if you can, how thick are the bolts that hold the plastic mesh piece.
Inches, millimeters, doesn't matter, just be precise.
Thank you.
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Feb 13, 2014 - 2:37 PM
Jeebus
Joined Apr 21, '13
From YYC
10mm bolts.
post Feb 13, 2014 - 2:47 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (Jeebus @ Feb 13, 2014 - 9:37 PM) *
10mm bolts.
Are you sure? Those be some thick bolts just for a plastic mesh.
What about the distance?
post Feb 13, 2014 - 3:43 PM
Jeebus
Joined Apr 21, '13
From YYC
Didnt get to take measurements as I was in a rush to get out for work. 10mm bolts for sure, as I installed a rain deflector bought from 6gc last year and I lost a bolt in my engine bay dring the process. I'll see whether I can get some measurements tonight when I get home.
post Feb 13, 2014 - 5:06 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (Jeebus @ Feb 13, 2014 - 10:43 PM) *
Thanks. And how long are the bolts?
post Feb 14, 2014 - 1:21 AM
Nial
Joined Aug 25, '08
From England
Depends which size you are looking for? The mesh has captive bolts attached to it.
Athough 10mm is the spanner size to remove the nuts securing it in place, this is not the sizing of them, they are I think M6 nuts although knowing Toyota they are probably a metric fine...I finish work early today, I will measure them for you after lunch and report back.
Do you want the size of the nut, or the size of the captive bolt?
This post has been edited by Nial: Feb 14, 2014 - 1:22 AM
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Feb 14, 2014 - 4:24 AM
Jeebus
Joined Apr 21, '13
From YYC
Here you go!
6 bolts: 3 on the top, 3 on the bottom.
The bolts are part of the grill itself.
Measurements of the bolts:
Measurement of the nut (10mm socket to remove it)
Measurement of the distances from bolt to bolt
Short side (Top side when looking down at the grill) 0", 5.5", 11"
Longer Side (Bottom side when looking down at the grill) 0", 7", 14"
I apologize, I realized as I was posting this that I should have used the metric side of the measuring tape since the measurements for everything in the car is metric.
This post has been edited by Jeebus: Feb 14, 2014 - 4:29 AM
post Feb 14, 2014 - 5:21 AM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (Nial @ Feb 14, 2014 - 8:21 AM) *
I want to know how thick it is, so I could figure out the radius of the holes they can go through. I'll be making a hood rain guard.
Looking at Jeebus's picture the bolt is 5-6mm
That's what I need.
Jeebus, thank you so much for taking the pictures and measurement.
post Feb 14, 2014 - 7:43 AM
The_enD
Joined Apr 12, '13
From Bulgaria
10mm socket corresponds to 6mm bolt, just measured some I had.
Lo-Fi Version Time is now: January 10th, 2025 - 5:52 AM
