> uk spec 1995 not starting
post Feb 14, 2014 - 7:40 PM
Joined Feb 14, '14
From uk
hello all..im running a 6th gen 2l gt st 202..1995 ...its uk spec..its been fine until last week..we wre on holiday for two weeks so left it at the airport..we came back at 2 am & tried to start the car..it was flat...ie no power/ignition lights,door interior lights..stone dead..the missus & me bumped started it..ie pushed it kept it in 2 nd gear & dumped the clutch ..it started first time..next day I replaced the battery..after checking voltage rate off the alternator..14 v ..so no alternator issue..i only ever had 1 x basic key..no keyfob..im sure this car has a built in immobiliser /transponder key..chip..but last night I couldent start it..it just kept cranking over..plenty of battery power..lights etc..it just keeps turning,turning over..i haven't took each plug out totest for spark,same with the relays fuses etc..I will do first thing tomorrow..where else should I look??..does the passenger side door work in unison with the drivers door ..ie unlock the car
post Apr 13, 2019 - 8:51 AM
asemblance
Joined May 29, '18
From London
QUOTE (111 @ Feb 14, 2014 - 8:40 PM) *
Hey 111,
Guessing you aren't going to see this - but having this exact problem, did you ever fix it? Any info would be appreciated, thanks!
A
Lo-Fi Version Time is now: February 18th, 2025 - 10:11 AM
