> Celi died, help?
post Feb 20, 2014 - 12:30 PM
cheela
Joined Feb 2, '07
From Berlin, WI
So this morning my celi died on me. It started just fine and I drove it to my girlfriend's place. then I got ready for work and went to start it again and nothing. looks just like it's a dead battery but pretty sure that's not it since I JUST drove it and the battery is a few weeks old only.
Seems like it doesn't get enough power to anything. lights dim and flicker, every once in a while they will come on and stay on full power though. but if I go to start the car, everything dies. car doesn't turn over or anything. also, I'm hearing some clicking almost like it's shorting sometimes when I turn the lights on. this was my diagnosis for the 5 minutes I had before I had to go to work so any help would be appreciated?
bad distributor? alternator? starter? relay?
post Feb 20, 2014 - 1:04 PM
mkernz22
Joined May 10, '10
From MA
jiggle the wires around on the battery and try starting it again. Might be a loose connection..
post Feb 20, 2014 - 1:08 PM
Barbershop
Joined May 5, '13
From United States
QUOTE (mkernz22 @ Feb 20, 2014 - 1:04 PM) *
Exactly why mine wouldn't start this past fall
post Feb 20, 2014 - 1:55 PM
cheela
Joined Feb 2, '07
From Berlin, WI
I'm gonna be so pissed and relieved if it's just something simple like that. I can only hope. Will try doing that and cleaning the terminals after work.
if not, any other suggestions?
post Feb 20, 2014 - 3:50 PM
get a multimeter and check bat volts.. prettu sure you have a 20 pound brick.
post Feb 20, 2014 - 6:09 PM
cheela
Joined Feb 2, '07
From Berlin, WI
ugh... you guys were right. turns out it was a loose connection
and also LOTS of corrosion built up underneath. Just didn't see it.
baking soda and water and it's all good. - relief!
guess 6 in the morning is too early to think straight.
post Feb 20, 2014 - 7:39 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
QUOTE (cheela @ Feb 20, 2014 - 6:09 PM) *
If you have any more issues let me know i can lend a helping hand since i'm maybe 20 mins away.
post Feb 20, 2014 - 8:02 PM
Jeebus
Joined Apr 21, '13
From YYC
I love it when the solution is just a little cleaning as opposed to buying a ton of new parts.
Glad you got it figured out. I had the same problem when I first got my car on the road, and it only cost me $8 for a terminal cleaner, albeit me buying a $90 Noco Genius battery charger.
post Feb 20, 2014 - 9:19 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (cyberblader1130 @ Feb 20, 2014 - 6:39 PM) *
yeah definitely. gotta do my axles this summer if you wanna help me with those.
PM me your number so we can meet up some time. I'm in Appleton every other weekend or so.
Lo-Fi Version Time is now: November 29th, 2024 - 10:58 PM
