> Helpppp st205 tranny
post Feb 20, 2014 - 11:47 PM
ToTheTop
Joined Mar 31, '13
From Georgia
I bought engine tranny combo from 3rd gen 3s and
I want to know is it possible to make this tranny fwd?
Looking to build up my 94 3sgte
post Feb 21, 2014 - 12:35 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Remove the transfer case and make a blanking plate?
Mike W
269awhp / 273ft-lbs
post Feb 21, 2014 - 1:29 AM
QUOTE (ToTheTop @ Feb 20, 2014 - 10:47 PM) *
its not an easy things, long story short you need a differential and a cover plate from an e153...
http://www.6gc.net/forums/index.php?showto...37&hl=e154f
post Mar 2, 2014 - 10:01 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
It has been said many times that if you run the E154 without the driveshaft and rear differential attached you will burn it up.
Just sell the awd tranny and buy an E153 from an MR2 Turbo, Camry or Solara.
post Mar 4, 2014 - 10:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you wont burn anything up, you just need to design a way to keep fluid in the trans without a driveshaft in.
the cover plate is a standard part on the MR2 E153. but you will also need a differential from an MR2 or Camry/Solara.
you do NOT want to get an MR2 trans. the linkage is on the wrong side and its not worth the effort to change over. just get a Camry/Solara 5 speed trans
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: January 9th, 2025 - 2:28 AM
