autometer vs prosport |
Mar 5, 2014 - 1:59 PM |
Enthusiast Joined Dec 19, '11 From billings mt Currently Offline Reputation: 1 (100%) |
looking to get a boost gauge that has lights so i can see it at night.
which do you guys think is brighter / easier to read at night? |
Mar 5, 2014 - 3:35 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
My prosports have been absolutely perfect. I highly reccomend them
Mar 5, 2014 - 3:42 PM |
that seems to be the usual for 6gc's from what i have seen on various build threads.did you go with mechanical or digital if u dont mind me asking.
This post has been edited by DaTerrorist: Mar 5, 2014 - 3:42 PM |
Mar 5, 2014 - 9:05 PM |
Enthusiast Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
I hear defi gauges are good. They're pricey but I've heard they're good.
Mar 6, 2014 - 1:39 PM |
so i think ive decided to get the prosport performance in green / white
http://prosportgauges.com/green_white_perf...nce_gauges.aspx or the Evo http://prosportgauges.com/evo-series-green-and-white.aspx the Evo series has a wideband afr that the other doesn't which is only reason im considering it. This post has been edited by DaTerrorist: Mar 6, 2014 - 1:44 PM |
Mar 6, 2014 - 4:05 PM |
Prosport offers guages that are basically a copy of defi's in every way, including the use of a stepper motor and opening sweep. I've found my set (52mm premium series) to be accurate and as responsive as I could ever need. I do not have a single negative thing to say. And one of the bonuses is that they can be wired to change colors depending on how you have the lowbeams switched.
They are pricey though, I think I paid close to $400 for boost, oil pressure, and wideband. Still cheaper than actual defi's though This post has been edited by enderswift: Mar 6, 2014 - 4:09 PM -------------------- |
Mar 6, 2014 - 4:53 PM |
i didnt much like the look of the premiums. the change of color thing is biggest reason i think im going with them.
im stuck between a grey / green / black OR white / gold / black color scheme for the car and with the green / white gauges that both of those are offered in i would be able to change if i dont like the scheme i end up with. i was unaware of the fact that they are just basically copies of defis. i only plan on 2 gauges for right now boost / AFR. probably going to end up with the EVO series though. I like the aspect of actually seeing the numbers and not having to read lines while driving (personal preference i guess) thanks for your advice swift. once i get them if i have any problems hooking them up would it be ok to send you a pm for some help? |
Mar 7, 2014 - 8:39 AM |
If you get prosport, get the premium clear lens series. The tinted ones are impossible to see in the day time.
Autometer is actually better when it comes to overall visibility. This post has been edited by lagos: Mar 7, 2014 - 8:43 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 7, 2014 - 9:03 AM |
hm think i would have to see a comparison. going to need more info before making my decision i guess
Mar 7, 2014 - 10:14 AM |
after little bit more research on the EVO series (as that is the ones ill be getting as of now at least) they seems to be powered once ACC is turned on and at night you wire them into light switch (splice into wire? or fuse) and at that point you can change the color if you want by simply using a different wire that comes with the gauge
of course im speaking only of the boost gauge right now but i imagine it would be the same for the AFR. i think when i wire them up ill make sure to take some pictures to do a write up on it as i haven't been able to find one on here This post has been edited by DaTerrorist: Mar 7, 2014 - 10:15 AM |
Mar 7, 2014 - 10:48 AM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
I'm a little old school with gauges. Autometer makes one that has the same dials and look as our OEM gauge cluster, so I go with them.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Mar 7, 2014 - 12:18 PM |
rabid any chance you can post a few pictures of the gauges? and do they light up at night?
Lo-Fi Version | Time is now: November 26th, 2024 - 11:22 AM |
