ECU Part Number |
ECU Part Number |
Mar 7, 2014 - 8:18 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Hey guys, there are several ecu's available on eBay for my '96 Celica 2.2 5sfe. I really don't want to pull my ecu out unless absolutely necessary so I was wondering if one of you would know which part number or model number I specifically need...
1996 Celica 2.2 5s-fe with manual trans and does have obd2. I found ecus to have the first 5 numbers the same: 89661 but it's the last 5 numbers that change...one reads 89661-2D870, one reads 89661-2D701, and I think mine reads 89661-2D4xx... Any help would be much appreciated. |
Mar 8, 2014 - 5:19 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Hey guys, there are several ecu's available on eBay for my '96 Celica 2.2 5sfe. I really don't want to pull my ecu out unless absolutely necessary so I was wondering if one of you would know which part number or model number I specifically need... 1996 Celica 2.2 5s-fe with manual trans and does have obd2. I found ecus to have the first 5 numbers the same: 89661 but it's the last 5 numbers that change...one reads 89661-2D870, one reads 89661-2D701, and I think mine reads 89661-2D4xx... Any help would be much appreciated. If you go to ToyotaDIY and enter your VIN number there, you should be able to find the information you're looking for. Enter your VIN, Continue, click on Electrical, then Electronic Fuel Injection System, and that's where you will find the part number for the Engine Control Computer you need. This post has been edited by MaskedMan: Mar 8, 2014 - 5:21 PM -------------------- |
Mar 8, 2014 - 7:32 PM |
That's what I was looking for! Thank you!!
Lo-Fi Version | Time is now: November 29th, 2024 - 3:57 AM |
