> what oil
post Mar 8, 2014 - 5:21 AM
fiddler69
Joined Jun 12, '12
From uk
gt4 st205 what grade of engine engine oil are you guys recommending please
post Mar 8, 2014 - 8:05 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (fiddler69 @ Mar 8, 2014 - 5:21 AM) *
5W-30
You could run a 10W-40 in the summer.
Synthetic Blend or conventional are ok, but I wouldnt suggest full synthetic unless your engine has been getting it for a while. 15-20 year old seals and gaskets dont like to switch from conventional to full synthetic.
post Mar 8, 2014 - 8:55 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Switching is an old wives tail, you need an oil which can withstand the thermal stresses of being run through a turbo charger, you need a good synthetic. I'd run 5w-40 full synth from Castrol or Mobil, whichever you prefer. You have more high quality oil options over there in the UK than we do here and 5W-40 is more readily available as it's more common for European cars like BMW's and Mercedes.
post Mar 8, 2014 - 9:13 AM
match220
Joined May 13, '06
From Kaimuki, HI
I just switched to full synthetic 5w-20 and an oil leak started that wasn't there before (or was very minimal). Before that I was running 10w-30 to break in the new engine that I finished building last year (switched at about 3k miles). I'm with Bitter, use synthetic for your car since it is turbo charged. Synthetic is very good at holding its viscosity under high heat conditions (like that generated from running through a turbo).
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Mar 8, 2014 - 9:24 AM
Neon90424
Joined Jan 19, '11
when the engine is new, you should just use reg mineral oil because you got to throw it out twice the first 1000 miles and go full synthetic. if you wanna go nuts diesel oils have more detergents in them but I don't know what would happen if you mix half diesel synth half reg synth
post Mar 8, 2014 - 12:38 PM
Bitter
Joined Mar 11, '06
QUOTE (match220 @ Mar 8, 2014 - 8:13 AM) *
post Mar 8, 2014 - 1:13 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Bitter @ Mar 8, 2014 - 7:38 AM) *
lol..thanks, but not necessarily true. it depends on how small the gap is that it is leaking from. It may not have been small enough for 10w30 to get through but 5w20 does perfectly when warm, which is why I said "or was very minimal" smile.gif
-Jay
post Mar 8, 2014 - 1:24 PM
Bitter
Joined Mar 11, '06
You just explained what I said and agreed with me, thanks.
post Mar 8, 2014 - 1:34 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Bitter @ Mar 8, 2014 - 8:24 AM) *
lol..kinda but not really
-Jay
post Mar 8, 2014 - 3:27 PM
Red123
Joined Oct 25, '11
From Tbilisi
I use 5w40 motul 300v for my car.
This post has been edited by Red123: Mar 8, 2014 - 3:28 PM
post Mar 8, 2014 - 4:00 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Bitter @ Mar 8, 2014 - 9:55 AM) *
Oh really? I guess it was just coincidence that I blew 3 gaskets within a week of switching to Royal Purple Full Synthetic.
My 94 GT started leaking out of the oil cooler, rear main seal and oil pump gasket.
post Mar 8, 2014 - 5:55 PM
Neon90424
Joined Jan 19, '11
if you blew 3 head gaskets your head is warped.
post Mar 8, 2014 - 7:06 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Neon90424 @ Mar 8, 2014 - 5:55 PM) *
You should probably reread my statement. Unlike the gaskets I did blow, which are subjected to moving parts and or oil pressure, the head gasket I DIDNT blow doesnt involve moving components or oil pressure. Therefore, It wouldnt make sense to suggest oil type causes a head gasket failure
This post has been edited by Special_Edy: Mar 8, 2014 - 7:15 PM
post Mar 8, 2014 - 8:22 PM
Bitter
Joined Mar 11, '06
The oil didn't CAUSE the failure, they were going to fail regardless and likely had been seeping for a long time. Synthetic oils have a much more uniform and often smaller molecular structure than conventional oils so any weak gaskets or seals that were just barely holding back conventional oil WILL leak synthetic oil but synthetic oil isn't the cause of the failure. Odds are good that those seals and gaskets were going to start leaking conventional oil pretty soon regardless of what oil you used.
http://auto.howstuffworks.com/switch-to-synthetic-oil1.htm this isn't the most technical of articles but it's full of truth for the most part.
post Mar 8, 2014 - 9:26 PM
Special_Edy
Joined Oct 29, '11
I would accept that answer for the rear main seal, but the oil pump and oil cooler were catastrophic failures. I understand that synthetic oil has a lower viscosity at low temperatures when compared to an equivalent conventional oil but this was 10W-40 which I run in the summer, versus the 5W-30 I run in the winter.
By stating that synthetic oil may cause leaks to become more apparent or worse you are conceding to my original statement that synthetics may cause leaks on a 15-20 year old motor that has never had synthetic in it, if the lazy PO's even bothered to change the oil. The odds are just greater. Period.
post Mar 9, 2014 - 2:34 AM
Bitter
Joined Mar 11, '06
Oil pump seals are always catastrophic failures, same for oil cooler seals. They're under pressure, when they let go they really gush a whole lot of oil very quickly. It's a 15+yr old car, so pretty much shame on you for never having changed the oil pump seal as they're KNOWN to be a problem with the 5S, same for the oil cooler seal as well. Blaming synthetic oil for lack of maintenance is like blaming Smith and Wesson for killing people.
post Mar 9, 2014 - 4:40 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Bitter @ Mar 9, 2014 - 3:34 AM) *
Shame on me for never having changed the oil pump seal on the car I paid $300 for.
If I had the oil pump off I would have replaced the gasket, but like the other 99.9% of celica owners I didnt replace every nut and bolt on the car just because. If I was that concerned I would have replaced the entire engine, not torn the whole timing assembly off to change one little gasket. Perhaps the most relevant bit of information here is whether or not the OP has recently changed every single gasket on his engine that touches oil. If not, shame on him according to you and dont use synthetic oil according to me. If he has changed every single gasket, then we both agree he can go ahead and use synthetic oil if he wishes.
If you reread my posts you will see that I already stated the oil pump and oil cooler gaskets are under pressure. So you have just invalidated your earlier arguement that the leaks were already there but got worse from the synthetic(also if the leaks were present, synthetic oil would instantaneously worsen the leak, not suddenly start gushing oil a week later).
Unless you have proof that can contribute to the arguement you are just making guesses and conjectures. Another member and I have stated that we first hand have experienced gasket failures following a switch to synthetic from conventional. Its up to the OP if he wants to accept your opinions or our facts.
post Mar 9, 2014 - 5:13 PM
RavenAegis45
Joined Jun 25, '08
From CA
Lo-Fi Version Time is now: December 1st, 2024 - 1:34 PM
