Leaking oil help :( |
Mar 14, 2014 - 10:44 AM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
Not sure where and why its leaking its leaking below the oil filter anyone have any ideas why?
Mar 14, 2014 - 12:25 PM |
ok you need to be more specific than that? pictures would help. is there a mating surface where its leaking from?
Mar 14, 2014 - 12:49 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
^+1. Need to be more specific. From what you provided. Sounds like you need to tighten the filter or need s new one.
Mar 15, 2014 - 9:00 AM |
The oil filter screws into the oil cooler. The oil cooler has two orings I believe. You will need a 30mm axle socket (rent it at the parts store).
Mar 15, 2014 - 4:51 PM |
Yep, either the oil cooler seal is leaking (the rubber becomes hard as a rock and breaks or just won't seal anymore), the filter is loose, or they left the old filter gasket on and tightened the new filter with it's gasket on top and well two gaskets don't seal better than one. Infact, two gaskets leak.
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:29 AM |
