POD filter |
POD filter |
Mar 17, 2014 - 9:09 PM |
Enthusiast Joined Nov 29, '12 From New Zealand Currently Offline Reputation: 0 (0%) |
Hey guys, i want some advice on a pod filter install
with the air temp sensor - how important is this component? Can i leave it hanging near the pod filter, or should i plumb it in? If i do plumb it in - Whats the best way of doing this? Get a small pipe extension from an auto store and drill a hole in the rubber, and slot it in? Ideas please - Liam -------------------- |
Mar 18, 2014 - 8:44 AM |
the proper way to install the temp sensor is to drill a hole, find a rubber grommet the right size and stick it in the tube. On my car when it was turboed, and Amy's car now, i just have it sitting in the engine bay. You need the sensor plugged in or you will get a CEL. (96+ years)
Mar 19, 2014 - 3:47 AM |
the proper way to install the temp sensor is to drill a hole, find a rubber grommet the right size and stick it in the tube. On my car when it was turboed, and Amy's car now, i just have it sitting in the engine bay. You need the sensor plugged in or you will get a CEL. (96+ years) Righteo, that was another idea of mine - Although i see one flaw; Because the pipe is round, and you've fitted the grommet, and slotted in the sensor, won't there be a gap? Between the bottom flat edge of the sensor, and the round pipe? Or is this something that won't affect it? -------------------- |
Mar 19, 2014 - 4:55 PM |
Provided the filter has a rubber bottom, which it should, take a soldering iron and burn out a hole. Be careful not to breathe any of it in, but it makes a perfect fit for temp sensors in the perfect location.
Lo-Fi Version | Time is now: November 29th, 2024 - 5:05 AM |
