> How can valve clearances get TIGHTER since rebuild???
post Mar 18, 2014 - 9:12 AM
Dudleydaftdog
Joined Dec 31, '13
From Yorkshire England
Hey all, just wondered please if someone could help me get my head round this...
After rebuilding my st205 head and working to Toyota spec (0.15mm - 0.25mm inlet / 0.25mm - 0.35mm) all of a sudden the head developed a loud knocking and a leak at the crank seal... After checking all of clearances (forged rebuilds now done 2000 miles) no1 cylinder exhaust valve nearest the cam pulley has shrunk to 0.20mm!!!. After turning the crank by hand it gets harder to turn as this valves opening...
I rebuilt the head with JUN valves and springs and HKS 256 cams. All was in spec after the rebuild. Thought clearances opened up as the engine broke in not got tighter! The engine was stone cold (left overnight) when I checked. The head was also proffionally rebuilt...
Could this be a worn valve seat possibly? Any thoughts/advice or previous experances pike this would be really appreciated.
Thanks
Chris : )
post Mar 18, 2014 - 3:01 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
The cam lobes and lifter shims are subject to slight wear. The majority of the wear to the valve occurs at the valve face.
The exhaust valves are especially prone to valve seat wear due to the heat of the exhaust gasses. Intake valves are cooled by the fresh air and fuel flowing in and generally wear slower.
I have a picture of a burnt exhaust valve from my old 5S head, the valve will literally shrink in diameter, causing it to sit farther into the head and the valve stem to be closer to the camshaft.
Try to reshim the valve into spec first and check it after a couple hundred miles. If there isnt a thin enough shim then a new valve and possibly a new valve seat will be needed.
The worst thing you can do is continue to drive it because as the clearance shrinks the rate of wear is accelerated (because the valve is open more and therefore cooled less by the head)
This post has been edited by Special_Edy: Mar 19, 2014 - 11:41 PM
post Mar 18, 2014 - 8:18 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Better pull the head to make sure you didn't get a mushroomed valve face.
post Mar 18, 2014 - 11:54 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Special_Edy @ Mar 18, 2014 - 1:01 PM) *
The cam lobes and lifter shims are subject to slight wear. The majority of the wear to the valve occurs at the valve seat.
you can cut off a few thousandths off the tip of the valve, you dont need a new seat in the head. In fact i dont recommend that. its more prone for a seat to fall in the cylinder.
like said above, if the valve is tight it will not seal and hang open, thats how you burn valves.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 19, 2014 - 9:40 AM
Dudleydaftdog
Joined Dec 31, '13
Thanks so much for all your help all. Have skimmed the shim by 0.10mm to put it back in the middle of the spec range. Wishing I'd used supertech valve seats now instead of OEM as the JUN springs/valves and tap happy cams must have put a lot of pressure on the valve seats. Highest my egt's reach is 1050f. Might try advancing my cams to run a bit cooler.
I used a Cosmetic 1.6mm HG, a friend of mind after the build said basically they are crap for st205s/185s because they are missing some of the coolant waterway holes (it all seemed to line up at the time ok?!? - St185 block with st205 heat and hg).. Is this true? Maybe to blame for the valve seat wear?
Many thanks again everyone for your info/thoughts.
Chris
Lo-Fi Version Time is now: November 25th, 2024 - 10:32 PM
