> Intercooler water Pump, Need Some Info Please Guys
post Mar 21, 2014 - 10:14 AM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Does anyone know the size of the intercooler water pump? Outlet/Inlet size, power output, pump speed, and overall diameter? Im looking in to getting a newer, lighter, and efficient water pump.
Unless the one Im currently running is sufficient: Here's the details
12V DC Water /Coolant Pump for Radiator/Heat Exchanger, Air to water Intercooler, Super Charger Applications.
Volume: 30L/Min (8 Gal/Min)
Inlet outlet: 3/4" (O.D.)
9500rpm Brushless Motor
Any opinions or info?
This post has been edited by Lil-Joe101: Mar 21, 2014 - 10:18 AM
post Mar 21, 2014 - 2:20 PM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (Lil-Joe101 @ Mar 21, 2014 - 10:14 AM) *
i'll go measure for you this evening
JN 3:16
post Mar 22, 2014 - 1:12 AM
JasonTX
Joined Mar 1, '10
From TX
inlet and outlet are using 1" hose and pump itself has a 3" diameter. didnt see any markings for flowrate or pressure but i'll take it out of the bracket that holds it and see if theres anything stamped on it later this weekend
JN 3:16
post Mar 22, 2014 - 8:28 PM
BriinumsBo
Joined Feb 6, '08
From Latvia
Dont think u will get better and more reliable pump than oem! If u do please let us know biggrin.gif
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Mar 23, 2014 - 3:24 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
There are really alot of good pumps on the market, each tested pretty throughly with our engines.
MR2 and GT4 guys generally run these
20mm CM90
http://global.johnson-pump.com/JPMarine/PD...JP-305_CM90.pdf
You should also check out this thread....
http://www.mr2oc.com/showthread.php?t=446283
(\__/)
post Apr 7, 2014 - 9:26 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
here you have a p&p pump i use on my st205 too
http://www.jabscoshop.com/marine/pumps/die...elf-priming.htm
you just need to manufacture some hose connections and a 54-killer
greetz
KEEP COOL UNDER PRESSURE
Lo-Fi Version Time is now: February 17th, 2025 - 1:48 AM
