> adjustable cam bolts, these replace the factory mounting bolts?
post Mar 21, 2014 - 10:50 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
These are available on rockauto
http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307
So do you just replace the lower two bolts that mount to the knuckle with these?
And will that adjust the forward/backward angle? (caster?)
I know to adjust the Camber you need those sliding plate top strut mounts.
Does anybody use these?
Mines not lowered but it's been punched in the nose before. I just want to make sure that once I get some new struts it will be fully adjustable so they can line it up nice and straight.
Bust a Deal; Face the Wheel.
post Mar 21, 2014 - 11:00 AM
mkernz22
Joined May 10, '10
From MA
'cam' does not equal the short for 'camber' bolts. just an fyi.
I thought you were talking about bolts for the camshafts in the engine for a sec lol
Camber bolts work just fine, I have them on my car.
I haven't used these ones before though.
I have two OEM ones and two aftermarket ones (they're on ebay).
post Mar 21, 2014 - 11:13 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Like what mkernz said. Cam and camber is two totally different things. Lol. But to answer your question. I have ichiba rear camber bolts and they work fine. You can use the oem "crash bolt" which is the same thing or he eBay camber bolts. They all work.
post Mar 21, 2014 - 11:28 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Right, I assumed "cam" meant like a cam lock mechanism like a cheap desk At target or something.
But I figured these would adjust the "caster" (front to back) angle, not the camber(side to side)
How about adjusting the tow in the rear do you have to buy some nice coil-overs before you can do that?
See how my tow is way off
http://www.6gc.net/forums/index.php?showtopic=92146
I assume most of this is because the struts and mounts are wasted, but I want to find out what other parts I should be replacing while I'm at it.
This post has been edited by VavAlephVav: Mar 21, 2014 - 11:30 AM
post Mar 21, 2014 - 12:01 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Toe is adjusted by the rear adjustable control arms. Front is adjusted by the tierod ends.
post Mar 21, 2014 - 12:34 PM
mkernz22
Joined May 10, '10
From MA
We don't have a caster adjustment. It's kind of a just adjust everything else to spec and hope that the caster is within the oem specs lol
post Mar 21, 2014 - 4:13 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
QUOTE (RabidTRD @ Mar 21, 2014 - 12:01 PM) *
ya know, after I posted it this morning and thought about it, that is exactly what I figured. ? the inner and outer tie rod would control the toe, and those arms in the back have some sort of a bolt on them too.
The deal is , when I got it aligned the guy told me that the toe in the rear wasn't adjustable, and that was as straight as he could get it without replacing some bent component.
now me thinks he's just too Lazy, if you look at that pic in the link it shows before measurements and after. it's as if he attempted to adjust the right rear a bit and then didn't finish it.
for $6 I should just get them anyway. but I think they're $6 each.
and I got a better look at them and what they do from the manufacturers web site
http://www.northstarmfg.com/car/1994/Toyota/Celica
http://www.northstarmfg.com/product/41-149.html
http://www.northstarmfg.com/userfiles/file...m3df(18164).pdf
This post has been edited by VavAlephVav: Mar 21, 2014 - 4:17 PM
post Mar 22, 2014 - 1:37 PM
mkernz22
Joined May 10, '10
From MA
^I would never use plastic inserts for the camber adjustment..
Anything that is bent should be replaced.
Lo-Fi Version Time is now: January 10th, 2025 - 7:16 AM
