> Not showing revs after swap, 3sge 2.0 GT 94 swapped out with a BEAMS
post Mar 23, 2014 - 7:30 AM
NICOGP
Joined Mar 21, '14
From Denmark
Hey everyone.
I have changed engine on my lovely Celica to Red top beams engine.
And I have had a lot of issues with wiring the damm thing, but the engine runs now.
I was interested in knowing how I get the revs to show in the dash, any special wiring?
I have also had some problems with the engine running well, and have come to a conclusion that the MAF is not working, because when the plug is on it runs really bad and goes out if not giving it rapidly revs. When the plug is off it runs more smooth and it doesn't goes out, but it's still not running perfectly and the engine failure light is on. I wanted to make sure that I have connected it correctly.
Can any of you confirm this wiring?
AIRFLOW SENSOR WIRING (MAF)
ECU CODE : D16 (RED/BLACK) TO POSITION 1 ON THE PLUG (+B)
ECU CODE : B1(YELLOW/RED) TO POSITION 2 ON THE PLUG (EVG SENSOR)
ECU CODE : B11 (BLUE/BLACK) TO POSITION 3 ON THE PLUG (VG METER)
ECU CODE : B22 (YELLOW/BLACK) TO POSITION 4 ON THE PLUG (THA TEMP)
ECU CODE : B18 (BRAUN) TO POSITION 5 ON THE PLUG (EARTH)
ST-202 BLMZF (BEAMS)
post Mar 23, 2014 - 10:23 AM
richee3
Joined Jun 29, '08
From Denver
The old engine used a distributor and the tach got the signal from that. The BEAMS uses COP's so it send a different signal to the tach. You either need to buy a BEAMS tach to swap into your cluster or buy a tach adapter to convert the signal.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 23, 2014 - 3:03 PM
NICOGP
Joined Mar 21, '14
From Denmark
QUOTE (richee3 @ Mar 23, 2014 - 11:23 AM) *
Where do I find such an adapter?
post Mar 24, 2014 - 12:33 AM
richee3
Joined Jun 29, '08
From Denver
You can find them on Ebay or any big vendors. Search for a Dakota Digital SGI-8 or MSD 8920. Either will do the job for around $80 USD.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: February 18th, 2025 - 4:28 AM
