> what oil???
post Mar 25, 2014 - 5:45 PM
Oreo20
Joined Jan 27, '14
From Houston
What kind of oil would you guys recommend
For my 94 Celica gt with 135k miles ???
post Mar 25, 2014 - 5:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Mar 25, 2014 - 6:00 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
10w-30 or 10w-40 if you're burning a bit
post Mar 25, 2014 - 6:19 PM
RoadRage
Joined Dec 9, '13
From Melbourne, Australia
i use 15w-40
post Mar 25, 2014 - 7:15 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
5w-30 is what's recommended by Toyota owners manual and is also what I use in my 5sfe.
post Mar 25, 2014 - 8:03 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Box @ Mar 25, 2014 - 6:55 PM) *
QUOTE (RabidTRD @ Mar 25, 2014 - 7:00 PM) *
These.
Seeing as how you are texas and its getting closer to warmer weather, the heavier oil is best
10W-30
エキサイティングカーレーシングチーム!
post Mar 25, 2014 - 8:09 PM
Syaoran
Joined Jan 4, '12
From US
10W-30 is what I use in my hot climate and it's very good. Oil pressure dropped to 10PSI at idle after a few boost sessions with my old, bad radiator and no oil cooler.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 25, 2014 - 9:26 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
how about additives? anybody use Lucas Oil? I use Rotella T 15-40 cause that's what Walmart has for $12 a gallon. then I spend the extra money on a good mobil one or Bosh filter.
Bust a Deal; Face the Wheel.
post Mar 25, 2014 - 10:50 PM
Syaoran
Joined Jan 4, '12
From US
I would spend money on better oil instead of any additives. For example if you're going to spend $30 on mobil1 and $10 on Lucas, might as well get a $10/qt AMSoil that will last you 7-10K miles without a sweat.
post Mar 26, 2014 - 12:40 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
I use CASTROL Edge 10w-30 in the winter and 10w-40 summer, accompanied by a synthetic grade filter like Fram Ultra Synthetic, K&N, or Bosch Distance Plus. I still change it every 3k miles
I also have a customer that runs Royal Purple and changes it once a year. Says it's still good when he takes it out (only drives about 15k) and is purple, in his Toyotas.
post Mar 26, 2014 - 1:38 AM
Box
Joined Feb 23, '12
From Warrior, AL
I use Super Tech from Wal-Mart and a Denso filter, Super Tech oil is made by Rotella/Shell.
This post has been edited by Box: Mar 26, 2014 - 1:38 AM
post Mar 26, 2014 - 3:12 AM
mi645
Joined May 23, '12
From northridge,CA
rotella t6 just as good as mobil 1 5w-40 full synteitc and its only 21 dollars a gallon from walmart
post Mar 26, 2014 - 8:02 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (VavAlephVav @ Mar 25, 2014 - 7:26 PM) *
I use the rotella T in my Supra.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 26, 2014 - 8:24 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
Ya I figure Rotella has a good reputation. And I tend to change it after less than 3k miles, because the motor is kinda old and dirty.
And I've got a small leak coming from maybe the head or rocker cover on the intake side kindasad.gif
post Mar 26, 2014 - 9:06 AM
Overkill
Joined Jul 27, '04
From Houston
Absolutely Nothing better than Mobile 1 Fully Synthetic.
post Mar 26, 2014 - 9:43 AM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
QUOTE (Overkill @ Mar 26, 2014 - 9:06 AM) *
Agreed! Mobil 1 Synthetic + Lucas Oil Stabilizer + OEM Toyota Filter. I usually run it for 5k minimum, i changed it every 3k during the first 2 years of owning the car.
Lo-Fi Version Time is now: February 23rd, 2025 - 4:43 PM
