oil mileage |
oil mileage |
Mar 28, 2014 - 3:35 PM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
How many miles do you run your oil before the next oil change ??
Mar 28, 2014 - 4:24 PM |
Enthusiast Joined Feb 6, '13 From Toronto, Canada Currently Offline Reputation: 3 (100%) |
I guess it depends on your mileage but I usually do it around 5k (90k) but in general it usually hovers around every 3-6k depending how forgiving u are
~DarkDeath -------------------- September 2014 & July 2015 Celica of the Month 1995 Toyota "EnDeR" Celica GTS-T Gen4 3sgte swapped [Instagram: @Ender_Celica] |
Mar 28, 2014 - 5:04 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
it may depend on just how high quality the oil you buy is.
but, what I've learned the hard way from other cars I've had is you should change it often and not wait until it really needs it. over time gunk will build up and may cause problems like blocking up the sump and just making the motor dirty. A lot of people like to run expensive synthetic and it goes for 7k miles. If you're like me and have an old dirty motor that's been abused and has 150k+ miles on it I would buy good quality oil(but I don't run synthetic), with an expensive filter like a Mobile 1 or Bosh, and then I change it every 3k miles (or less). the real test is to check your dipstick at least once a week, and change it as soon as the oil looks dark or burnt even if it only has 2k miles on it. if you keep doing this you'll clean up that old motor. I also advise against using things like Seafoam IN the crankcase. just because it does a REALY good job of knocking loose all the old crud that's in the corners of the motor and that may cause you even more problems if you have an old neglected motor. -------------------- Bust a Deal; Face the Wheel.
Mar 28, 2014 - 5:21 PM |
3-6K for conventional and 10-15K for synthetic dependent on driving conditions and quality of the oil.
Mar 31, 2014 - 12:19 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
High mileage Dino oil, change every 4K miles
-------------------- God made man....
Everything else... Made in China |
Mar 31, 2014 - 1:54 PM |
Enthusiast Joined Oct 24, '09 From Appleton, Wisconsin 54915 Currently Offline Reputation: 7 (100%) |
Mobil 1 Synthetic - 5k miles or more depending on how dark the oil gets.
Mar 31, 2014 - 5:32 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
I use the Castrol High Mileage Part-Synthetic 5w-30 oil ever since I've owned it. Also changed my oil every 2500-3000 miles. I just like to be extra safe and keep the oil away from building/sludging up in my engine.
Mar 31, 2014 - 5:41 PM |
Enthusiast Joined Jan 27, '14 From Fort Wayne IN Currently Offline Reputation: 0 (50%) |
3K unless synthetic which I go UP TO 5K. I usually freak out and change it at 3K anyway. This is usualy recomended by the oil company, not the car. Some cars say go higher, but the additives in the oil deplete after a certain time that could cause higher heat, friction, and sludging conditions. Id like to make sure my seals and internal parts wont wear quicker just because I want to save 500$ at the end of my cars life.
CHANGE YOUR OIL, or THINK WITH YOUR DIPSTICK JOHNNY! -------------------- 94 Teal GT-DD 223,915 miles SOLD
99 WHT GT- Race car! Or just AutoX Car getting rebuilt then susp and turbo! |
Apr 1, 2014 - 7:54 AM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
I use full synthetic. I change it every 3-4k. I base my oil change on the viscosity break down... If I beat on my car, and I notice the oil is a bit thin/worn out and it's not giving the usual pressure, I change it.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 1, 2014 - 8:34 AM |
Where do you go about getting an oil pressure gauge setup?
I'd love to get one and install it in one of those clusters that replaces the side molding up the windshield. Not having an oil pressure gauge to watch kinda bugs me. -------------------- Bust a Deal; Face the Wheel.
Apr 1, 2014 - 4:46 PM |
Where do you go about getting an oil pressure gauge setup? I'd love to get one and install it in one of those clusters that replaces the side molding up the windshield. Not having an oil pressure gauge to watch kinda bugs me. There's a how to around here somewhere, it's not too terribly hard to do. -------------------- 2001 Miata LS 5-speed
Apr 1, 2014 - 4:52 PM |
Enthusiast Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
I use Castrol GTX High mileage. I change it every 2000 to 3000 miles.
Apr 1, 2014 - 6:08 PM |
I can see if I have all the info on it... Otherwise I can walk you through it. It's incredibly simple. You're just running a t off of the oil pressure sensor location (if you want to keep the factory light as well) and running brass tube (or wire if you do an electric setup) into the cabin. Then you wire the lights and that's about it.
Lo-Fi Version | Time is now: November 29th, 2024 - 10:39 PM |
