2 Pages V  < 1 2
> PCD change from 5x100 to 5x114.3, is it possible with no adaptors?
post Nov 6, 2014 - 1:50 AM
luka
Joined Jul 23, '08
From Hawaii
that's actually not a bad way to do it.
the outer ring ID is probably -0.001 of what the OD of the old hub, if cut on a lathe, its pretty well balanced.
interference press fit...the majority of the stud is still on the original hub so the ring takes a little of the slack.
not much difference than some stuff I make at work for planes, actually never thought about this use on car hubs.
post Nov 11, 2014 - 3:29 PM
underground_desi...
Joined Dec 4, '11
From Greece
QUOTE (luka @ Nov 6, 2014 - 1:50 AM) *
that's what I would say if my English were good enough.
Only one thing
the outer ring is welded on the hub, then machined and balanced.
It's one piece. o way it goes anywhere.
I'll try to get some more pics if it's possible because it's installed now.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 21st, 2025 - 6:04 AM
