Timing belt |
Timing belt |
Apr 3, 2014 - 5:29 PM |
Enthusiast Joined Jan 27, '14 From Houston Currently Offline Reputation: 0 (0%) |
How often does this need changing ???
Have you guys done it if so how much did you pay for the change? |
Apr 3, 2014 - 10:09 PM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
http://www.6gc.net/forums/index.php?showtopic=73956
this is where all the sticky threads are for maintenance. for the most part the timing belt should be replaced about every 100k miles. though some of the early 5sfe specs say to change it every 60,000 miles. and when you take it apart you should be sure to replace the timing belt, tensioner and idler pulleys, and the tensioner spring, along with the water pump. I'm not sure but I would guess a shop would charge 6-8 hours of labor for the job. so guess $75-90 an hour for labor, and list price for the parts maybe another $200. I went to rockauto.com and ordered a kit with all the parts for $65 and put it on myself. ...it took me a bit longer than 8 hours though, and had to take it back apart again after the first time until I got it right. but it's a good bonding experience with the machine -------------------- Bust a Deal; Face the Wheel.
Apr 7, 2014 - 3:18 PM |
thats a good quote, 8 hours of labor and 200 in parts. since you are in Houston, hit up my buddies shop ddperformanceresearch.com he is a toyota engineer. they can do the job for you at im sure a better rate.
Apr 7, 2014 - 4:01 PM |
Wow almost $800 just for the labor of a timing belt job?
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Apr 7, 2014 - 4:52 PM |
It's non-interference, just run it until it snaps.
Apr 8, 2014 - 8:32 AM |
Enthusiast Joined Aug 31, '13 From Wyoming Currently Offline Reputation: 0 (0%) |
^^^ This... Drive er till spits the belt. THEN use this website to learn a little something about your car All the info is here, and its really not that difficult. Did mine in 5 hours... Hard to imagine a "Toyota Mechanic" taking 8 ?!?! $$$$$$
Apr 8, 2014 - 8:43 AM |
quick question for the beams, is it basically the same?
align the marks and the notch? i know parts are not -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 8, 2014 - 8:56 AM |
Enthusiast Joined Oct 3, '10 From Lansing, MI Currently Offline Reputation: 2 (100%) |
^^^ This... Drive er till spits the belt. THEN use this website to learn a little something about your car All the info is here, and its really not that difficult. Did mine in 5 hours... Hard to imagine a "Toyota Mechanic" taking 8 ?!?! $$$$$$ +1 for letting it snap,. and this was practically the first thing I researched on 6gc,.. now I think I know every nut and bolt on them. |
Apr 8, 2014 - 9:02 AM |
quick question for the beams, is it basically the same? align the marks and the notch? i know parts are not Well the 5sfe only has one cam pulley while the better motors have two. Still just line the hole in the pulley up with the notch on the head. I think its a good idea to use some bright color nail polish and make your own timing marks BEFORE you take the old belt off. And when you put it back together turn the motor over by hand Twice to be sure those marks and the mark on the crank pulley all line up. This post has been edited by VavAlephVav: Apr 8, 2014 - 9:02 AM -------------------- Bust a Deal; Face the Wheel.
Apr 8, 2014 - 10:08 AM |
Wow almost $800 just for the labor of a timing belt job? Ya , they fkk you at a shop, and be sure those are the cheapest parts out there. I'd agree you could run it till it snaps, but you may sooner have problems with the water pump. -------------------- Bust a Deal; Face the Wheel.
Apr 8, 2014 - 11:48 AM |
It's non-interference, just run it until it snaps. This^ You can change it out in a couple hours if you know what youre doing, if you arent mechanically inclined it could kick your butt the first time round. But if you go to all the trouble of changing it out you should also change the waterpump, oilpump and/or gasket, crankshaft seal and camshaft seal. May also want to change out the idler and tensioner pulley. Easily $1000 to $1500 with parts and labor. I mean whats the point in changing the belt for preventative reasons and not everything else in that area? Thats why you should just leave it alone until something breaks. As stated its a non-interference motor which are uncommon. On most engines when the timing belt snaps the pistons will hit the valves, destroying the motor, but on ours nothing happens except the engine dies until the belt is replaced. Its your time(potentially stranded) vs your money(for something that may not need replaced). It's non-interference, just run it until it snaps. This^ You can change it out in a couple hours if you know what youre doing, if you arent mechanically inclined it could kick your butt the first time round. But if you go to all the trouble of changing it out you should also change the waterpump, oilpump and/or gasket, crankshaft seal and camshaft seal. May also want to change out the idler and tensioner pulley. Easily $1000 to $1500 with parts and labor. I mean whats the point in changing the belt for preventative reasons and not everything else in that area? Thats why you should just leave it alone until something breaks. As stated its a non-interference motor which are uncommon. On most engines when the timing belt snaps the pistons will hit the valves, destroying the motor, but on ours nothing happens except the engine dies until the belt is replaced. Its your time(potentially stranded) vs your money(for something that may not need replaced). |
Lo-Fi Version | Time is now: November 30th, 2024 - 1:57 AM |
