> Oxygen sensor help
post Apr 18, 2014 - 4:40 PM
Island_Racer
Joined Sep 9, '08
From Jamaica
Just need a little help id-ing some wires.
The connector for the o2 sensor broke in my hands and now i need to know which wire (harness side) connects to which wire (sensor side), so if anyone could just pull theirs and let me know, that would be awesome.
Harness Side:
1. White
2. Black and Yellow
3. Blue and White
4. Brown
Sensor Side
1. White
2. Blue
3. Black
4. Black
I have tried a few combinations however am tired of blowing my efi (15A) fuse...
This post has been edited by Island_Racer: Apr 24, 2014 - 11:19 AM
post Apr 18, 2014 - 5:46 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Island_Racer @ Apr 18, 2014 - 2:40 PM) *
Harness Side:
1. Black and Red
2. Black and Yellow
3. Blue and White
4. Brown
Sensor Side
1. White
2. Blue
3. Black
4. Black
What chassis is your car?
post Apr 18, 2014 - 9:29 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the 2 black wires are the heater circuit. they should be pins 1 and 2. the others are the OX signal and ground.
on on the sensor plug, pin 1 is the heater signal back to the ECU.
pin 2 is the +B 12V when you turn on the key. so isolate all the wires, turn the key on and find the wire that is giving you 12V
pin 3 is the signal wire to the ECU, im not sure if it mates up with the white or blue wire on the sensor plug.
Pin 4 is the brown wire, its the ground.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 19, 2014 - 1:07 AM
Island_Racer
Joined Sep 9, '08
From Jamaica
QUOTE (ILoveMySilly97 @ Apr 18, 2014 - 6:46 PM) *
Harness Side:
1. Black and Red
2. Black and Yellow
3. Blue and White
4. Brown
Sensor Side
1. White
2. Blue
3. Black
4. Black
ST205
post Apr 19, 2014 - 1:12 AM
Island_Racer
Joined Sep 9, '08
From Jamaica
QUOTE (Smaay @ Apr 18, 2014 - 10:29 PM) *
Saying pin 1,2 etc wont help me, the connector (harness side) broke and i only have the 4 colored wires sitting. I get that two r for the heater circuit, one for o2 sensor and the last is ground. But apart from knowing the brown is ground. What r the others.
post Apr 20, 2014 - 6:28 PM
Island_Racer
Joined Sep 9, '08
From Jamaica
ok i figured it out so if anyone needs to know after this.
Harness Side ----------> Sensor Side
Brown ----------> White
White ----------> Blue
White/Blue ----------> Black
Yellow/Black ----------> Black
the blacks dont matter the order.
This post has been edited by Island_Racer: Apr 24, 2014 - 11:18 AM
Lo-Fi Version Time is now: February 23rd, 2025 - 6:49 AM
